Source for Hysol 9460
Does any know of a good inexpensive source for Hysol 9460 adhesive? Any suggestions would be appreciated.
Any Hysol product direct from dealers will be expensive. The 9460 mechanicals indicate 3500 psi lap shear and 3% elongation. The 9430 which is available from Aircraft Spruce has 3500 shear and 6% elongation. The higher elongation means a tougher adhesive with high peel. Both are considered thixotropic (non sag).
I'd go with the 9430.
