I just finished a new video on applying latex paint with a roller. After the sanding and polishing process the results are nearly as good as spraying. Both methods, spraying and rolling have their advantages.
Spraying gives the best finish, itís faster for big areas, and requires less sanding to smooth the orange peel. But, you need spray equipment and a paint booth the contain the over spray, and you need to mask parts that you donít want painted.
Rolling is faster for smaller areas and requires no masking other than along edges, it needs no paint booth or equipment, thereís no over spray. But, it requires more sanding to remove the orange peel and while the result is quite good itís probably not quite as good as spraying.
Have a look at the video and let me know what you think.
https://www.youtube.com/watch?v=OhlxE3EFcCQ
Merry Christmas
Malcolm Morrison
www.wienerdogaero.com
