I have made a dipole antenna, following the instructions found on the web. This looks great and I hope it works!
The problem is that it is, of course, by definition twice as long as a more usual 1/4 wave aerial and my Boredom Fighter fuselage can't accommodate the full length, which has to be vertically orientated.
The handiest way I can mount it inside the rear fuselage, just behind the seat bulkhead, results in about 16" of the top element of the aerial sticking out above the turtle deck, into the airflow. The arms of the antenna are made from 3/32"(appx) piano wire and I'm not too confident they will survive the 100mph airflow, without whipping about and thrashing my Boredom Fighter to pieces.
First question is: is this likely?
The second question is: could I safely bend the lower element of the aerial back, at its lower end, such that I could mount the whole thing lower down and keep the entire antenna inside the fuselage? Think I have seen somewhere that these aerials will tolerate a short length being bent back to clear the airframe, without losing much performance. This would also save a little unwanted drag and maybe prevent leaks through the turtle deck.
I plan using this aerial to maximise the efficiency of the small hand held radio I have to use in the open cockpit of the Boredom Fighter.
Look forward to any advice.
Thanks. Ian
