Results 1 to 4 of 4
Thread: Pitts S1-D wings
    Pitts S1-D wings
    Hi
    I'm new to this site and a member of the LAA (EAA equivalent) here in the UK.
    I am looking at a rebuild project of a Pitts S1. The set of wings I am looking at are S1-D, (flat bottom section with 4 ailerons) they have built up ribs and the compression ribs have square sections either side.
    The help I need is to obtain a set of plans for the wings so I can make sure they 'conform' and obtain the relevant approvals, I have drawings for the S1-S which helps with the fuselage etc but not wings.
    If anyone can help with plans/information I would be most grateful.
    Best regards
    Stuart
    New Hampshire
    I would suggest starting with the folks at Steen Aerolab. They sell plans for the S-1C and the four aileron wings.
    Hi Wes
    Thanks for the reply, I've been in touch with Steen Aerolab and they don't have plans for the S1-D, I think the four aileron wing they do is the S1-SS which is a symmetrical wing.
    Stuart
    Byron J. Covey
    Guest
    Quote Originally Posted by tipsynipper View Post
    Hi Wes
    Stuart
    From http://www.steenaero.com/pittss1/
    The S1-C is the "Flatwing" Pitts Special, which was the first model for which plans were offered back in 1962. The S1-C uses the M-6 airfoil on both wings, and has ailerons on the lower wings only (a four-aileron model is available, please ask for details.)
