Vintage Aircraft Grade Mahogany Plywood for sale
All,
I saved 10 sheets of 3/32" aircraft grade mahogany plywood from my father's estate. There are a total of ten 4' by 8' sheets. 9 have have the grain running along the longest dimension and on one the grain is oriented at 45 degrees. All sheets are marked as aircraft grade and were made between 1965 and 1967. The plywood has always been stored inside. I've sold several sheets for $100 each. I will consider reasonable offers, especially if you were to take most or all.
Thanks for looking
Steve
Sorry, I haven't been checking, but I see little interest. I still have the plywood and will consider offers that are even more reasonable - to you.
Where in the country is this?
Somewhere in OH??? I'll give you $100 for all 10 sheets if that's the case.
