Results 11 to 15 of 15
Thread: ADS-B
    Decaturville,Tn. 38329
    Anyone who says there is no difference in the display between ADS-B and XM obviously hasn't used them. There is no comparison !
    I used to use XM on about 2-3 days per week for about 10 years in the southeast year round. I have, for the past 10 months, used an ipad/Foreflight and the Strattus 2 ads-b. The only significant difference I've found is that the update rate of the radar display, at times has been as long as 40 minutes and usually is about 5-10 minutes whereas XM was consistently 6 minutes. The inconsistency is just not acceptable. It needs to be updated as quickly as possible.
    Dallas, Texas, United States
    There is a fairly balanced review of the 3 different sources for inflight weather data at: http://airfactsjournal.com/2013/09/t...alink-weather/
    Below is an image of XM, Regional FIS-B and CONUS FIS-B Nexrad from the article:
    For my purposes, FIS-B provides the information I need for my type of flying. Others may want or need something different.
    Quote Originally Posted by S3flyer View Post
    I concur. It's certainly better than what I had previously. Like most things in life, you just need to understand it's limits and shortcomings.
    Bob Leffler
    RV-10 Flying
    www.mykitlog.com/rleffler
    I am using Garmin Pilot using the Garmin GDL39. Do any of the other apps have any better resolution than the Garmin or they all the same?
