Hi,
I read the prop balancing article in the October issue of Sport Aviation with interest. I have several fixed pitch props, but all have a 2.25" hole, not .75" as described in the article. I have not found a company that makes a fixture for static balancing props with the larger hole? Is this something people are having custom made by a machine shop? ... as in, several bushings with a rod through the middle? Any advice would be appreciated.
Thanks,
Brian Vickers
Bainbridge Island, WA
