I did not want to hijack the very good thread on EAB vs LSA. Is there a list of EAB aircraft that can be flown under sport pilot?
If not can we start one?
“It's the greatest shot of adrenaline to be doing what you have wanted to do so badly. You almost feel like you could fly without a plane.”
-Charles Lindbergh
Its a weight thing, speed thing.
Fisher Flying Products all fit into this class, as do Mini-max's. Most your Rans if not all Rans aircraft can be flown SP. Some Sonerai's fall into the SP class. The two seat stretch low wing is one. Some build and fly these as SP.
That's about all off the top of my head I can think of but there are many many more. Just all that come to mind right now.
Tony
I am particularly interested in older designs.....
-Charles Lindbergh
When you say older you mean airplane design older or a company that has been around a long time?
Look at Dawn Patrol. That is an Old design.
Fly Baby, Pietenpol, Volksplane, Cuby and variants... I'd guess more than half of all homebuilt designs would qualify as LSA.
Older as in aircraft that were designed in the 60s, 70s, and 80s. Aircraft that were designed and plans built...
-Charles Lindbergh
The original poster wanted a list of EAB aircraft that could be flown under Sport Pilot. Then the request was changed to request older designs that could be plans built.
Just to be complete, the Sonex line of aircraft (Sonex, Waiex, Xenos, Onex) can all be flown by a Sport Pilot. All are kits except for the basic Sonex, which can be plans-built (as in, you buy all the raw material and fabricate your own parts, down to welding the tube components) or kit built.
I believe some of the older Zenith designs may be SP compatible, but I wouldn't wager more than a Coke on that information. I believe some of them are also plans-buildable.
With apologies to Jack Nicholson, "You wanna a list, you can't handle lists", but these come extremely close to ultimate lists:
Firstly, here's the list of LSA qualifications:
http://www.eaa.org/en/eaa/aviation-c...ort-pilot-rule
Here's a list of FAA approved E-AB Kits:
Amateur-Built Kit Listing - Federal Aviation Administration
Here's a directory database of E-AB including plans-built that's quite exhaustive:
http://www.pilotfriend.com/experimen...craft_list.htm
All you have to do now is take the time to make a comparative analysis and then pick your poison. Be careful what you ask for and have fun.
