The whole point, I think, is that a prop...like a gun...should never be treated
casually. Always handle both as if the worst-case event could happen. On cold days, I turn the prop over (backwards) by hand to loosen it up a bit; I have to move the prop to remove the cowling from my airplane. In all cases, I keep as much of my body out of the danger zone as possible.
Bill's objection, and my agrement with it, is that taking a photo with the airplane *is* a casual event. No reason to touch the prop or get in the arc.
Years ago, I came out to fly, and a buddy's T-18 was parked on the taxiway outside his open hangar ready to go. I figured he was out visiting the sani-can, and took off for a short flight. When I came back, it was still there. I called my buddy's home number, and he WAS there...and hadn't been to the airport that day.
Someone had tried to steal his airplane. Fortunately, his master switch was in an odd position, and they probably were stopped when they didn't find it. But it's not beyond the realm of possibility that they'd got the engine primed and ready to start. The mags were toggle switches, didn't need a key to start. If they'd wanted to cover their tracks, they could have tucked the airplane back in the hangar with no one the wiser...and the engine ready to go. As it was, the T-18 shared the hangar with an Ercoupe, and it took some trickery to fit them back together (they'd actually dropped the Ercoupe onto the T-18's wing in getting the homebuilt out, its tiedown ring gouging the skin).
In any case, this could have been a case of an airplane ready to go, with no (legitimate) person the wiser.
(The full story...which is even weirder...can be found at
http://www.bowersflybaby.com/stories/witch.htm)
Extremely low probability, yes. But not messing with the prop unless necessary is a good policy....
