Quote Originally Posted by Mike M View Post
The Airgas facility in Flagstaff, 2004. Saw their servicing facility. One tank of LOX fed a manifold. On the manifold, takeoff fittings labeled "welding", "medical", and "aviator breathing" along with the appropriate warnings, hazmat labels, regulatory gobbledegook. One LOX tank, one manifold. I'll believe what the reference said. I'll also believe what I saw in practice by one of the biggest and most reputable companies in the business, a subsidiary of one of the largest companies in the business worldwide, to meet those standards. Of course, the world has changed a lot since 2004.
The manifold described is very common when being fed from a Liquid Oxygen Tank, evaporator, and compressor as the vendor is using 99.999% pure LOX. Each outlet has a check valve thereby they can feed to aviators oxygen, medical, and welding tanks without the issue of contamination. In reality, all tanks are filled with the 99.999% purity oxygen. LOX used to be around 60 cents per gallon delivered.
vr... Don Stits
