It also frequently leaves an oily mess on the airplane which needs wiped off.
Jim Rice
Wolf River Airport (54M)
Collierville, TN
N4WJ 1994 Van's RV-4 (Flying)
N3368K 1946 Globe GC-1B Swift (Flying)--For Sale
N7155H 1946 Piper J-3C Cub (Flying)
Learned alot from this thread. As for the altimeter I do have one but like to keep my eyes outside the cockpit. For wind, I never fly when there is wind above 6 mph. My airplane has such low wing loading it's just no fun when its windy or thermals are out. Early morning or late evening is my type of flying.
Tony
And then there's the Pietenpol crowd, who've smoked for years! A couple of them use pump-up jugs (garden bug sprayers) sitting on the seat next to them. I myself have never partaken, just reporting what I've seen for several years at the Brodhead Pietnepol fly-in.
The Piet builders are creative folks. I wonder if they do morse code messages with their pumps and smoke.
My Exhaust Gas Temp gauge reads 1500F 4" down the exhaust stack from the cylinder. A few inches farther down where the smoke oil fittings are I doubt the gas has cooled below 1000F.
Correct me if I'm wrong, but don't some use transmission fluid as a cheaper alternative? I've even hard that used, dirty (free) fluid smokes best.
ATF makes nice white smoke but the cost is higher not lower. You also might need to thin it a little with diesel. I will suggest that dirty fluid might clog your nozzles and make wiping the belly down even more annoying.
Corvus oil wasn't designed for smoke systems. It's a light oil used for both wood preserving and as a release agent (to keep concrete and stuff from sticking to the forms/molds). Some other release agent oils are easier to come by in smaller quantities and those are often used.
The VansAirForce guys have tons of articles on smoke systems. It's not all that involved if you're in an experimental. My friend made his own tank for a starduster. A small electric pump and a nozzle inserted in the exhause will work. There are some commercial systems that have had field approvals for certificated aircraft.
