Thread: Air Command Elite CLT Gyro
    Jul 2014
    Bountiful, Utah
    Selling my Air Command Elite CLT. this is a mid 90s frame with a center line thrust up grade. New (not rebuilt) 8 hr TT Rotax 532, new "A" gear box, 60" Power Fin 3 blade prop. 24' Dragon Wing Alum. Rotors. I have spent the last year going thru this Gyro and replacing everything that need to be replace to make it air worthy. I am selling because I just found out at Rotors over the Rockies this year with a thrust test that it would be below marginal performance at my weight and altitude. FAA registered as an Experimental. N number stays with aircraft and current airworthiness certificate. This would be a great gyro for a 190 lb pilot. Asking $15,500 with 14' ramp gate ATV trailer or $14,500 without. Located in Norther Utah.
    If interested in this gyro call Mark 801-514-6928
