You can only fly a non-radio aircraft if you can make it into the UL runway. The FAA strongly discourages NORDO approaches to the regular runways (it used to be they had a published procedure for this, essentially similar to the WARBIRD arrival) but the deprecated that years ago.
So you visit a county owned airport for a week a year, and expect them to cater to you for the other 51? I fail to see any reasoning for that. EAA doesn't own Wittman by any stretch of the imagination. If there were that big of a demand for a non controlled area, it would be there already for the locals. Obviously there is not.
Aaron, what I expect is that EAA should cater to all aviation and especially Sport Aviation not business aviation. And EAA should be working to see that all local public airports are open to sport aviation where possible. I don't expect Sport Aviation at ORD, but KOSH should be open to non radio sport pilots in some way. I checked the KOSH live cams yesterday, and didn't see any air traffic at all, just two days after Airventure.
I am still trying to find current numbers for KOSH revenue operations.
I just read an article in my local paper here, it said my local airport has had it's scheduled air service cut from 6 flights down to two per day. There never was a tower here. ( Fairchild International, Port Angeles, WA.)
edit, according to Wikipedia, KOSH doesn't have airline service now since 2003. So I remain confused why the Class D remains.
http://en.m.wikipedia.org/wiki/Wittman_Regional_Airport
Ok sorry I missed that you had a radio. Future sport pilots will know they cannot land a controlled fields. A look at a sectional where I live shows many uncontrolled grass and paved strips for non radio aircraft to land. I have no desire at all to fly without a radio but if I did, I could find plenty of places to land.
Bill,
EAA is not Wittman Regional Airport. If you have an issue with KOSH, take it up with Winnebago County. Ive got an idea for you Bill, move here, build a hangar, make KOSH your field, then come to the county board meetings, bring up your ideas and proposals including how to absorb the added cost of a grass strip and such. Let the board consider and vote on it. If you are so deeply concerned about this, then im sure you will have no problem devoting yourself to the cause. Im not being sarcastic either....like Henry Ford said "Find a solution, as anybody can complain".
