Want to see 87% warbirds using the P & W R-985 "Wasp Jr." 450 HP radial engine?
I am in the process of planning to introduce 87% kits of the T-28 "Trojan" military trainer, using the P & W 450 HP "Wasp Jr." radial engine (same as used in the PT-17 Stearman and Dehavilland Beaver), in composite form. That will be followed by the F4U Corsair, Sea Fury, FW-190 Focke Wulf, Japanese Zero, AT-6 "Texan", and others. This is kind of a market survey. Any ideas on how popular these might be? The R-985 can be had for around $43,000, and, apparently, are readily available. I will try to have the first T-28, even if not flyable yet, at Oshkosh next year. Any input would be appreciated.
