I have the Mecco Midget.
Can someone please explain the best way to get the Midget up and running?
What procedure and pressures do you use?
Should I do anything different going from small tips to the larger tips?
I feel like the flame I have is too small; it's almost attached to the nozzle (tip #2). Trying a #4 tip, I can't get a neutral flame; I barely add O2 and it pops or, other extreme, I can't get enough O2 to get the inner flame down. I don't understand what's wrong as I've read the manuals and watched EAA videos, etc. The tanks are nearly full.
I couldn't find an answer searching the forums.
Thank you,
John
