Results 1 to 10 of 11
Thread: Unchecked Carnage - USA Today Report
    Jim Rosenow's Avatar
    Smithville, OH
    Interesting reading if you have the time....
    http://www.usatoday.com/longform/new...rt-2/10405451/
    RickFE's Avatar
    Feb 2012
    KHEG FL
    I read through the series. It seems to me, that the article lacks a lot of texture. For openers, comparing the record of airlines to that of GA is disingenuous. GA covers pretty much anything that isn't airline flying to include higher risk activities such as aerobatics, air racing, crop dusting etc. Airlines, are tightly governed and fly the same routes over and even train on specific routes that they fly. If one wanted to pull the same strings, we could compare the "carnage" of to "amateur" driven car transportation to that of professional bus driving. I bet a lot less people get hurt taking a bus to work or to the store, than people in those tiny little cars.
    Hatchet Job article
    The articles appear to be textbook hatchet jobs. Some of the most obvious misrepresentations are found in the repeated use of "amateur pilots" and "amateur-flown aircraft". Another boner is when the author states "On Thanksgiving eve in 2011, Russel Hardy had no warning of the sheer cliff ahead of him...". Really? No maps or knowledge of the location of the mountain were available? Many of the author's claims are outright wrong and not just in detail.
    It's pretty clear that Thomas Frank had to dig to find numbers to support many of his conclusions when you see the lack of date agreement. He groups 'deaths since 1964' with other periods, with no analysis of rates of change over the past 50 years. Totally disingenuous.
    However, it is fairly difficult to argue with the point that the NTSB and the FAA could do measurably better in accident prevention analysis and reporting. We've known for decades that the incestuous relationship between the FAA and the NTSB is not good for aviation and the pilot population always gets the short end of that stick.
    USA Today: right up there with Fox News.
    Aaron Novak's Avatar
    Oshkosh, Wi
    So......whats this guys personal agenda?
    Jonathan Harger
    Guest
    Here is a good rebuttal article to the USA Today smear job: http://www.huffingtonpost.com/jeff-s...b_5509253.html
    Also, here is EAA's response to the original article: http://www.eaa.org/en/eaa/eaa-news-a...isleads-public
    Here's another rebuttal by our very own Bob Collins, fellow EAA member and RV'er.
    http://blogs.mprnews.org/newscut/
    Bob Leffler
    RV-10 Flying
    www.mykitlog.com/rleffler
    Richard Warner's Avatar
    Covington, LA
    The best thing that could happen to stop a lot of these lawsuits against the manufacturers is to allow the NTSB probable cause to be used in court. I don't know why it shouldn't be allowed.
    Two words Aaron, Deborah Hersman.
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by Richard Warner View Post
    At least part of the reason is that manufacturers, which now play a valuable role in these investigations (as even the story alludes to) would probably clam up and refuse if they knew that their efforts would be used against them later in court. Kind of like the NASA safety reporting form- how many pilots would file them if they didn't come with the guarantee of immunity from prosecution (or at least sanctions being levied.)
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    May 2012
    There is no doubt that the series was written following the chapter notes right out of the book of Sensational Journalism!!!
    Yes it is a gross exaggeration but what exactly did they do? They took FACTS and with twisting and manipulation made a sensational story that angered all of us directly concerned with aviation!
    But if we work through our initial anguish and eliminate the distortions and exaggerations, we are left with the FACTS that were presented…
    How did an aircraft get certified with a flawed rotor system? How is that instead of fixing it, we only require the pilots to have an endorsement about it?
    Why did it take almost 50 years of active denial to produce a simple fix for the Model 35 Bonanzas?
    Some aircraft are more susceptible to post crash fires than others yet pilots as well as manufactures ignore solutions that have been around for years!
    As Experimental Builders we have the greatest latitude in what we can do.
    So the best thing we can do with this horrible hatchet job, is to leave it with an attitude and goal to approach ALL safety issues from a creative standpoint.
