Kitfox Partially built 7 SS
Kitfox for Sale
2008 Kitfox 7 SS 2008
Grove Landing Gear, heavy duty ( allows higher gross)
Tail wheel and Nose gear
Parking brake
Storage kit
Upholstery kit, Suede
Aveo ball air vents (2)
Cowl
Scoops, NACA
Engine:
Jabiru 3300A S/N 33A 2223, never started or turned over, purchased in 2010
Electric carb heat for Bing carb
Low fuel warning indicator in header tank
Quick oil drain
Complete Firewall Forward Kit for Jabiru engine, including engine mount
Odyssey PC 680 Battery
Propeller: Sensenich ground adjustable, 2 blade RH, composite with metal edges, short shank, 64” diameter. Blade S/N 26465, 26695, Hub S/N 28820B. New in box. Never assembled, never on a plane,
Avionics:
GRT 8.4” Sport SX High Res Screen, with AHRS, Synthetic Vision
Fuel Flow meter
Servos (2) for auto pilot Pitch and Roll
Garmin 327 Transponder
Icom IC A210 comm
Garmin 496 in AirGizmo mount
PM 1000 intercom
ACK ELT EO4
EIS Display
Hobbs meter
Compass
12 V plug
Pilot and CP PTT with trim control
RA Miller Comm Antenna AV529
Electric Trim with indicator
Covering Materials:
Poly-fiber covering fabric 35 yds.
Poly-Brush 8 gal
Poly-Tone 9 gal #105 Insignia white
Poly-Spray 9 gal
Poly-Tak 1 Qt
Poly-Fiber Paint Cleaning Solvent C-2210 Gal 1
Poly-Tone Blue 1 Qt
MEK 4 Gal
Poly-Fiber Reducer R 65-75
8 gal
All of the above are unopened and stored in basement at normal room temperature, Never subjected to heat or freezing temps. Bought in 2010.
More pictures are available at DropBox site. Contact me for link. wkharryman3@gmail.com
Bill Harryman
