Thread: Kitfox Partially built 7 SS
    Kitfox for Sale
    2008 Kitfox 7 SS 2008
    Grove Landing Gear, heavy duty ( allows higher gross)
    Tail wheel and Nose gear
    Parking brake
    Storage kit
    Upholstery kit, Suede
    Aveo ball air vents (2)
    Cowl
    Scoops, NACA
    Engine:
    Jabiru 3300A S/N 33A 2223, never started or turned over, purchased in 2010
    Electric carb heat for Bing carb
    Low fuel warning indicator in header tank
    Quick oil drain
    Complete Firewall Forward Kit for Jabiru engine, including engine mount
    Odyssey PC 680 Battery
    Propeller: Sensenich ground adjustable, 2 blade RH, composite with metal edges, short shank, 64 diameter. Blade S/N 26465, 26695, Hub S/N 28820B. New in box. Never assembled, never on a plane,
    Avionics:
    GRT 8.4 Sport SX High Res Screen, with AHRS, Synthetic Vision
    Fuel Flow meter
    Servos (2) for auto pilot Pitch and Roll
    Garmin 327 Transponder
    Icom IC A210 comm
    Garmin 496 in AirGizmo mount
    PM 1000 intercom
    ACK ELT EO4
    EIS Display
    Hobbs meter
    Compass
    12 V plug
    Pilot and CP PTT with trim control
    RA Miller Comm Antenna AV529
    Electric Trim with indicator
    Covering Materials:
    Poly-fiber covering fabric 35 yds.
    Poly-Brush 8 gal
    Poly-Tone 9 gal #105 Insignia white
    Poly-Spray 9 gal
    Poly-Tak 1 Qt
    Poly-Fiber Paint Cleaning Solvent C-2210 Gal 1
    Poly-Tone Blue 1 Qt
    MEK 4 Gal
    Poly-Fiber Reducer R 65-75
    8 gal
    All of the above are unopened and stored in basement at normal room temperature, Never subjected to heat or freezing temps. Bought in 2010.
    More pictures are available at DropBox site. Contact me for link. wkharryman3@gmail.com
    Bill Harryman
    Bill,
    i'm checking to see what the status of this listing is. Fuselage & wings?
    Thanks much,
    Skot
