What a great 2 cents. I myself would like to see more posts from you and some pics.The four place Bearhawk would be a homebuild that would do it all except the 170 kt cruise. They have a large baggage area and big door for loading and a quick build is available. If you just want to fly, the C-182/180 is my choice. I've got thousand of hours in them and never cease to be amazed at what they do. In the Arctic I've moved our family several times with nothing but the airplane because we lived where there are no roads. I would have killed myself in any other airplane. You have to work hard to kill yourself in one of them. No one would believe what we do with them and what they will do. Again, no 170 kt cruise, but they get you there before the weather changes very much, normally. For years we hauled all our groceries and virtually everything we bought, in it. I put quick release pins on the door hinges to remove the door for loading, took the stop off the window so I can open it all the way out in flight, added Flint tip tanks and Monarch mains for a 7 hour endurance. We had one once with the 18 gallon baggage aux tank. Start with new cylinders, overhaul them once and then new ones again. Never, ever, install a cylinder with unknown history that you didn't buy new and you won't have to go through the emergency forced landing. I've flown it into Russia four times, over the Bering Sea out of Nome. Packed our family of five into it all over Alaska and northwestern Canada. You have to take the seats out for hauling big loads, but you can really get a lot into it. They carry some ice if your day turns sour...if you don't know what the day holds, spray some silicon on the prop and wipe it down..ice won't stick to it. Not the most efficient fuel burn like some of the cleaner designs, but it does things they would never think of...there is just nothing that does it "all", but the 182/180 comes the closest of any. Especially if you have to land in impossible shears & crosswinds, it will keep flying when anything else would never be able to recover. Just my 2 cents...
Tony
