Thread: And another RV7 flys
    Took my friend's RV 7 N177NR up for the first time on Friday May 23. Brief flight as I only got 30mph on the airspeed indicator so I just went around the pattern and landed. Flew it for around an hour on the 25th and everything worked really well. Strong engine with no cooling problems so it should be a good one. Don
    gbrasch's Avatar
    Arizona
    Congrats to you and your friend, what a great feeling. And you have a great transition trainer up by you, Chris Droege, would recommend him highly to the owner.
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    This is the 8th RV I've test flown and will transition the owner. I've been flying RVs since 1991 and have flown all the models except the 12. Great airplanes. Don
    gbrasch's Avatar
    Arizona
    Quote Originally Posted by pittsdriver3 View Post
    Didn't know that, then you are the man!
    Glenn Brasch
    2013 RV-9A
    Jul 2013
    Gonzales, LA
    Congratulations! Any pics of the new bird?
    Woohoo!
    And, as I've said before, it's not another RV, it's your RV, unique in its own right. Or, rather, his.
    On the low airspeed, how did indicated versus another method (say, GPS ground track) differ? It may be too early for that in the testing period, though.
