Results 1 to 10 of 14
Thread: new to aviation and need some advice on purchase
    Hello all, my daughter and i are going to buy an airplane, nothing fancy, but something to train and build time in etc etc.
    we are student pilots pursuing sport pilot certificate. our CFI has made a great case for us buying our own plane to train in and build time in, so i have financing lined up etc etc, but need help with direction. two planes that we are considering right now are
    1946 taylorcraft bc12-d midtime airframe and low time c-65 connie motor, that is supposed to be good, hand prop, conventional taildragger, etc price is right, it is a certified aircraft and it qualifies Light sport, but it is several states away. has all logs since 1950's.
    1979 STITS SKYCOUPE SA7-D Tri Gear, 0-200 Connie low time on airframe and mid time on motor, but annuels good etc, this one is less money, meets Light Sport also, Pilot is elderly and ready to get out of the plane, and is a talker, sounds like he would do anything to help get my daughter and i our license. seems like very nice guy. I know this is an E - AB plane, but that maintenance etc will be easier on us than on the taylorcraft, that being a certified craft. This one is only 5 hours away in the next state which is a plus. this one has all logs for past 20 years.
    help, which way should i look???? already had to move away from an ERCOUPE, the guys logs didn't look quite right, seemed like a lot of time missing for engine, so i backed away.
    what can you knowledgeable people recommend? I have no problem with any and all maintenance on the AB, been building things, trailers, vehicles, tractors etc for 30 years, so that isn't a problem.
    thank you for your help.
    micheal
    Define your mission and the plane will present itself to you. Or the style of plane will anyway. From the plane you describe I would say you want to fly for the fun of flying and not really worried about going from point a-b.
    I love the taildragger but they are not for everyone.
    Tony
    Dec 2011
    Arkansas
    A lot of people like the panache of a tail dragger, but the tri-gear will probably be easier for you an you daughter to learn in. Also 1979 versus 1946 is a lot of extra years for tubing to rust, etc.
    At any rate, welcome to flying!
    thank you all. i like the idea of one of ray Stits nicest planes, i think i might try and see how that one looks etc. thank you for your input!
    Joe Delene's Avatar
    Wisconsin
    I like your idea, of buying a plane. How about a simple Cherokee 140? It's a great plane to start with, price should be right.
    If you have never purchased or owned an airplane before, the safest, lowest stress, lowest cost path is to purchase one of the smaller, all metal, Cessnas or Pipers. An airplane is not a lifetime commitment, so once you have earned your pilot certificates, you can sell and apply your new experience and knowledge to purchasing a ship that more closely matches your interests. A Cessna 150 or Piper Cherokee will allow you to complete all of the learning objectives required for your pilot certificate, have good support from your local mechanics and parts suppliers, and are proven, reliable ships. When you move away from the common choices and into experimental or antique/classic, you risk lots of distractions away from your primary goal of flying to earn your pilot certificate. You are best served by playing it safe with your choice of airframes and focusing on earning the certificate.
    You should also contact an aviation insurer to explore what your potential purchase is going to cost you every year. Common airframes are less expensive to insure than less common ones, and expect to hear that your entry-level student status increases the cost also. If you give the insurance broker the airplane info, to include age, total hours, type, they can offer you a quote.
    Whatever your choice of airframe, do not skip the first step of hiring a mechanic to do a pre-purchase inspection of the engine and airframe. It is very worthwhile to pay a mechanic $500 to avoid making a $10,000 mistake. Many first time buyers have experienced great stress and financial pain by skipping this step. This step is likely going to be your first learning experience about aircraft ownership and maintenance. Hire a mechanic who is not the sellers mechanic and listen to what they have to say.
    Aviation is a great adventure. More than you can guess standing at the door looking in.
    N6234A
    N78041
    I can't stress enough the importance of the three items that Wes highlighted.
    1. Piper and Cessna entry level aircraft are going to be cheaper to buy, maintain, and insure. I had a Cherokee 180 for almost four years. I got my instrument rating and my son got his private. I even invested $20k into the panel. I sold it and broke even on the purchase cost. You may not be able to do this with other model aircraft. Buy something inexpensive to get you and your daughter's ratings, then sell it to get something that fits your mission better afterward.
    2. Always talk to your insurance agent first. Some aircraft just don't have a good history with low time pilots. I know a sitituation in which two pilots each built the same model experimental. One pilot had 350 hours and the other 150 hours. There was a $7k difference in their insurance premiums for this particular airframe. Several folks have tried to get their spouse on their policy, but no uunderwriters were willing to insure zero time pilots on this experimental. You want to know what your insurance will be before you make an offer. It may even cause you not to look at a particular model. I suspect that there will be a premium bump for a zero time pilot in a tail dragger. If you want to fly something that may be expensive to insure (and you can't afford self insuring) then build time in the trainer until have appropriate ratings and time that will make the insurance more affordable.
    3. Never buy any aircraft that a mechanic that you hire and doesn't have any relationship to the seller does a complete annual or pre-sale inspection. Yes, this will cost you money. When I was shopping for my Cherokee, the mechanic found damage history that the current owner wasn't aware of becuase they didn't do their due diligence when they purchased the aircraft. Also make sure you get a copy of all data on file in OKC on the aircraft in addition to all the logs. There are several firms that will get the FAA records for a small fee. This is how the damage history in my situation was discovered.
    Bob Leffler
    RV-10 Flying
    www.mykitlog.com/rleffler
    thanks all, i am glad to have all the suggestions on here. one problem is that we are pursuing sport pilot certificate and and most planes don't meet the Light Sport Class. the taylorcraft and the Stits both do but the Faa list is pretty short for certified planes that meet lsa. some Luscombe, some Aeronca, some Ercoupe, the Taylorcraft all from the 1940's, then we move to S-LSA and most of them are $55,000 and up to well over $100,000, so that is pretty much out, so then we come back to insurance if i can get it on the Experimental, so i will go there right now and see what i can find. thanks very much for your help.
    Banned
    There are other used choices you might consider amongst the previously known group of ultralights that are now LSA's. Check out a Challenger, it has a great rep and the company has a long history of being in business.
    ok, thank you will do. i appreciate it.
