NOTAM Link
I attempted to download the notam off the new web site. All the links take you to:
https://www.eaa.org/en/airventure/ea...-oshkosh-notam
The old link (http://www.airventure.org/flying/2014_notam.pdf) just takes you to the link above on the new site.
But I can't find a link to download the notam pdf or even the form to fill out to request the hard copy.
I hope it's me missing the obvious and not an oversight of the new web site.
No download issues on this end Bob.
The link on the page your first link shows takes me to:
https://www.eaa.org/~/media/files/ai...2014_notam.pdf
which appears to be the notam pdf file directly.
I found the issue, which is that the new site isn't compatible with I.E 8. Yes, I know it's old, but I don't control the browser level on the office desktops. Unfortunately, we have some key applications that don't support more modern browsers.
The objects just below the notam paragraph that have the links to the hardcopy and pdf versions don't render when using IE 8.
Bob is correct, the new site is not compatible with IE8, and like Bob, it is an office issue. On the blogs page I can not see the links to the blog posts either.
