I have an A-65-8 that just been overhauled. I'm getting 7 lbs of pressure at idle on left side of engine and no pressure on right side of engine.
Installed a new accessory case, oil pump gears and cover plate. New spring and plunger for oil pressure relief. I'm get oil to main bearings, camshaft journels, and to cylinders on left side. Get oil to right chamber but not to cylinders on right side and no oil pressure. Dismantled engine checked tolerances on all components, every thing is fine. Anybody out there have any ideas? Not sure where to go next.
