Results 1 to 10 of 10
Thread: What engine is this?
    Mar 2014
    Does anyone know what engine this is and what aircraft it was used on?
    Pratt & Whitney R-5600 Quadruple Wasp. Pretty sure somebody at Reno had way too much time on their hands! I'm sure there's a full back story on this one somewhere that will turn up.
    Zack
    It's 2 4360's bolted together. Doubtful it even runs.
    Mar 2014
    It's pretty wild that you knew where the picture came from. Thanks for the replies.
    Sep 2012
    Just think of the gallons per mile you could get with that!
    Biggest problem here would be if it did run what would somebody ever do for a prop for such a monster if you got it running correctly it could be 8000 Horsepower..
    Quote Originally Posted by DennisB View Post
    use the countra-rotating props from a Griffon, x2 (double countra-rotating? lol)
    The Griffon engine peaked at about 3500 Horsepower Most of the single RW4360's were 3500 to 4500 Horsepower and that double 4360 would have to be a real beast it would be interesting to see if the Counter rotating Griffon prop could effectively use all that Horsepower ?? Maybe a prop from the Russian TU-94 Bear if one could be obtained . But then prop diameter may become an issue ?? But that would sure give WWII fighter an awesome rate of climb .. The only factory single engine airplane I know of to use the 4360's was some of the Martin Maulers ..
    Goodyear F2G?
    Oak Harbor Wa
    The last 11 Corsairs had 4360s on them.
    Super Corsair variants[edit]
    Main article: Goodyear F2G Corsair
    The F2G-1 and F2G-2 were significantly different aircraft, fitted with the Pratt & Whitney R-4360 Wasp Major 4-row 28-cylinder "corncob" radial engine and teardrop (bubble) canopy. The difference between the -1 and -2 variants was that the -1 featured a manual folding wing and 14 ft (4.3 m) propellers, while the F2G-2 aircraft had hydraulic operated folding wings, 13 ft (4.0 m) propellers and carrier arresting hooks for carrier use.[116] As World War II was drawing to a close, development problems emerged that led to the abandonment of further work on the F2G series.[117] While only 10 were built, several F2Gs went on to racing success after the war, winning the Thompson trophy races in 1947 and 1949.
