There's a free app on Google Play, that helps you initiate ATC flight following. Try it out let me know what you think.
Peter
Link: https://play.google.com/store/apps/d...ile.contactatc
or go to Google play and search for 'Private Pilot ATC Help'
Brief description:
This app is for VFR Private Pilots, it helps you locate an appropriate Air Traffic Control Facility and Frequency. It will also display the information you need to provide to ATC for the initial contact. It uses your phone's GPS to provide proper location information for Air Traffic Controllers to pin point you on their Radar. You can now toggle between the most 10 probable ATC facilities and frequencies that can offer you flight following. You do this by Swiping to the Left/Right on the display. BTW, The application and Data is for the US Only
