Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 79
Thread: Buttercup Project - Steve Wittman -First Flown in 1938
  1. #61
    Brrrmidji , Minne-SNOW-ta
    Vac-u-form machine
    Wow , impressive machine after looking at Utube homemade rigs.
    I asked Dave about posting his "contact " info in case youz guyz might need something vac-u-formed.
    Some of the things he showed me that he has designed and molded were very professional looking .
    I also learned about using Textured plastic sheets ...
    Dave Ekstrom
    Director of Engineering
    4125 Hangar Drive NW
    Bemidji MN 56601
    PH 218-751-1880
    dekstrom@bemidjiaviation.com
  2. #62
    Plenum Cover
    . The scars on the aluminum were hidden with some engine turning .
    http://www.wingsforum.com/viewtopic....18465&start=75
  3. #63
    I got it sealed up with Chaffing material and a layer of Wool
    Nothing to see here...
    Wow.... I was surprised to finally come back and find no replies.
    I thought I posted some good stuff , obviously no one seems interested in a Buttercup...
    Saves me time ...
    Gotta Fly...Baby
    JAM ( Just Another Mike )
  5. #65
    Well I dunno, seems folks have been following your work for some 8 years and 67,464 views? I'm not sure what you expected during this your last absence for a year from making a post? Looks to me like some nice work on this lengthy project?
  6. #66
    Sometimes your work is too good to comment on ---
    What have you been doing for the last year?
    What is this most recent part and why is a nut taped on the Knipix(sp?) pliers?
  7. #67
    Quote Originally Posted by DonN View Post
    This is an example of the Modification....I can JUMP a flange to squeeze a rivet
    Different size nuts work...I use two sizes so far.
    The tape has NO PRESSURE...It only keeps the nut aliened
    I thought of this during my Plenum fabrication
    https://www.wingsforum.com/viewtopic.php?f=320&t=18465&start=75#p54514
    PS Thank you for the complement....That's a new one
  8. #68
    OK - I turned a thick (1/2") die for the rivet squeezer to jump a flange. Works great.
  9. #69
    Don't feel ignored... Your reply was censored ...
    PS 67 thousand? ... Thanks Frank
  10. #70
    Yipeeeeeeeeeeeeeeeeeeeeeeeeeeee
    Hey Guys,
    I guess the Wings Forum is getting repaired and should be back in a day or so.
    I'll finally get to update my building log, , it could be viewed,but I haven't been able to post since about August ( 7 mos )
    Meanwhile ...I just happen to see a picture with those knipex (?)
    The first way I was jumping a flange for riveting...The jump block was floating...it had to be held til pressure was applied.
    later I came up with using nuts because SIZES are easy to change,
    and they are held to the tool with a simple piece of tape, leaving metal to metal contact.
