Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: Buttercup Project - Steve Wittman -First Flown in 1938
  1. #51
    When you go Up North , We're just North of that
    Bridged
    I've got the back wall cleco'ed to each side , still more to go
  2. #52
    funny bends took funny brake pieces
  3. #53
    here's the piece in place , still a rough fit
  4. #54
    more paper turned into aluminum
  5. #55
    Any thing wrong with cutting this here ?
    I drew the black line first , I like the straight cut the red line is showing .
    Sealing it... Small piece of aluminum to overlap and a little bit of high temp silicone to make a vulcanized sandwich.
  6. #56
    Excellent work!
  7. #57
    Thanks Frank , I'm waiting to hear some progress on....hmmm does your plane have a name ?
    My first planes name is Miss Lucky Stars....
    Cause every time I fly her I'm thanking my lucky stars
    my second plane took years to come up with the right name ...Mystical Madness
    "Miss Tickle Madness"
    It seems to fit .
    I think I heard you call her something before ...but can't remember ...
    Waiting for updates
  8. #58
    Baffling - Daylight
    More Baffling Pictures.
    I have Dzus fasteners on a lot of this lower Plenum.
    I plan to hold the top cover in place with them too.
    So far...the lower pieces weigh 2 lbs 4 ounces
    It's strong and comes apart easy.
    I made a drill template for the Dzus lay-out...Banding material works good.
  9. #59
    more baffling pictures
  10. #60
    clear wing tips
    hmmm, I stuffed the Buttercup in the pole barn while I work on my Kolb FSII.
    Then an opportunity to vac-u-form my wing tips / strobe cover came up .
    I looked through my old experiment , found a piece that I can use ...after a little bit of repairs
    Here's some pics ...They might have been formed last night , I'll post those pictures later.
