Back on the Carb Heat Box
I made a frame to hold brass screen...
From here it will also get a filter laying flat on the Brass / with oil on it ( Like Rotax )
It will clean easy.... The cowl will also have a heavier screen and filter
I'm working on the Carb heat "air supply" at a near by exhaust pipe...The Scat will be short
Pictures @ 11
