Results 1 to 7 of 7
Thread: Icom A20 Fast Charger
    falcon21's Avatar
    Wisconsin
    I have an Icom A20 radio but I am missing the charger for it. Anyone know where I might find a fast charger for it? I contacted Icom and they no longer have them, not surprisingly considering the age of the radio.
    Good will type stores generally have a large selection of chargers at very reasonable prices. Sort through to find the right voltage and adapter. If necessary wire in a new adapter. Want 12 to 14 volt DC. 14 volt for fast charger. If necessary I could look up voltage and MA rating on my radio.
    Jim Heffelfinger's Avatar
    http://www.mypilotstore.com/mypilotstore/sep/2004 .
    If it is a NiCad battery and over 1 year old or a NiMH and over 3 years old it is time for a new battery pack. These packs are known for cells that are not matched and one cell will bring down the pack leaving you with a fraction of the pack rating. Using a cycle/charger will help extend the battery life and identify the bad cell but the cost of replacement with a new pack is fairly low. If there is a Lithium battery pack available in the same battery case (might take some research) then make the shift - it will need a different charger but well worth the effort. Reliability taks a huge leap forward.
    Icom uses many of the same batteries for a huge selection of radios - most unrelated to aviation.
    http://www.aircraftspruce.com/catalo...countbatt6.php
    Replacement battery packs that fit - ICOM BP-8, ICOM BP-8H, ICOM CM-8, ICOM CM-8H,
    http://www.my-batteries.net/two-way-...com-ic-a20.htm
    I have a alkaline cell pack for several of my portable radios - especially ones I rarely use. I replace batteries once a year rotating the cells to flashlights and other less critical items. I always have fully functioning radios ready to go and an easy swap of cells if I need more operation time. Rechargeables left on the charger are always a guess.
    My best to you
    Jim
    falcon21's Avatar
    Wisconsin
    Could you? I checked the manual and it didn't specify the rating of the charger.
    Yes, note that the Icom A20 shares accessories (batteries, chargers, etc...) with their line of both commercial and amateur radios. I believe that's the same pack as the HAM 2AT radio and I forget the designation on the commercial radio (I had one for a while). There are some on EBAY for sure (though they appear to be non-icom units). The wording by the way is "rapid charger" in the industry which may help your search a bit.
    I think this one will work (genuine icom even)
    http://www.ebay.com/itm/Icom-BC-35-C...item3f354fd4af
    falcon21's Avatar
    Wisconsin
    Thanks for the link Ron.
