Results 1 to 10 of 38
Thread: Mass produced vtol aircraft to eliminate eventual global gridlock of ground vehicles
Threaded View
    Bill Ford, CEO of Ford Motor Company, stated recently that personal transportation will become limited, not by the price of fuel or CO2 emissions, but by congestion (http://www.ted.com/talks/bill_ford_a..._gridlock.html). We will rapidly approach a point where traffic simply stands still, and that will limit our personal movement.
    I have a patent pending on a new transportation vehicle that is designed to run on natural gas or any other bio-fuel at several hundred miles per hour at a lower cost per mile than the Prius.
    The Verticraft is the ultimate transportation vehicle of the future. It has maximum speed and safety at minimum cost. Very high speed on the ground is very dangerous, while very high speed in the air is desirable and very safe. On the ground, vehicles are separated horizontally by a few feet with zero vertical separation. In the air Verticraft will be separated by hundreds or thousands of feet horizontally and by hundreds or thousands of feet vertically, making air travel thousands of times safer than driving. Residents of low-density, residential-only sprawling communities are also more likely to die in car collisions which kill 1.2 million people worldwide each year, and injure about forty times this number. The incredibly large costs involved in having to build roads and bridges to desired destinations and the destruction of the environment caused by those roads would be eliminated. The vehicle is designed to run on LNG or any bio-fuel to minimize emissions. A ballistic recovery parachute allows the Verticraft to make a normal landing in the unlikely event of multiple engine failure, because it is a vertical takeoff and landing vehicle. If anyone does not believe that electronic collision avoidance systems work, check the accident record. Before collision avoidance systems were perfected and then made mandatory there was a tragic series of collisions involving airliners. Since the electronic systems went on watch there hasn’t been a midair involving an airline jet. It is a little known fact that the public has been flying on an automated airline flight system for years. Only three minutes of the average airline flight is not operated on autopilot.
    The aircraft would be totally automated. Each property owner would enter their address and each 12 'circular parking spot number into the FAA's NextGen system using the Automatic Dependent Surveillance - Broadcast (ADS-B) system. The desired address and spot number would be entered into the Flight Management Computer. The FMC would reject any flight path that would have a traffic or weather or spot occupied conflict. The aircraft would all have TCAS ( traffic collision avoidance systems) connected to the autopilots that would take evasive maneuvers automatically just as the current airlines have TCAS warnings for the pilots to take manual evasive maneuvers. This system would automatically be activated by ambulance, police, or fire vehicles which have priority. The response time and efficiency of emergency vehicles would be greatly enhanced. If a spot at your desired destination is unavailable the nearest spot available would show on the cockpit display screen along with the nearest spot available to your current location at all times. At major airports the airline flights would operate in their normal flight corridors while inbound passengers would fly in unobstructed routes to their parking spots available near or on the terminal building. Passengers that live nearby could send their aircraft home as UAV's to free up parking spots. Rental aircraft would be available to international airline passengers. This would minimize the current causes of fatalities from automobiles such as falling asleep, alcohol, drugs, texting, many other distractions and last but not least, incompetence. Air taxi vehicles would be available for the people concerned about automated flying. The aircraft could be flown manually in low density airspace just as they are currently and still have the TCAS available to maximize safety as a backup to visual flight. The automated air transportation system would be used for transportation to the edges of high population areas where only mass transit vehicles are allowed. A good example is Disney World's transportation system.
    The initial market would be the 600,000 licensed pilots in the USA along with the estimated 400,000 foreign pilots. I would like to discuss a joint venture to mass produce the Verticraft to replace the current fleet of cars, trucks and aircraft and eventually eliminate global gridlock and dependence on foreign energy sources.
    Sincerely,
    Stanley G. Sanders II, President Verticraft LLC.
    email- j2sande@yahoo.com
    phone- 239-248-0747
