Scott F, Thanks for the heads up as to what actually happened within the ARC. I do find it a bit curious as to why the National Ar Traffic Controllers Association (NATCA) was involved in an ARC concerning Airworthiness Standards (Part 23) ?? Be that as it may, the approach used per your statement; "So, what was needed was an angle here. We came up with was that we would not invent anything new, everything proposed in the ANV category was a rule already in use today with a proven safety record. Obviously maintenance came from Experimental AB, the conversion back and forth to standard category from restricted category, the repairman’s certificate from LSA." while novel, is akin to the old axiom about; A camel is what you get when you design a horse by committee !!
Any way a question or two. Wouldn't deregulating aircraft carrying a Standard Airworthiness certificate take a whole new section of the FAR's to accommodate and administrate? Will companies (Cessna, Beech and Piper for example) still holding many ATC's of PNC eligible aircraft, support those conversions with approved data such as drawings etc ? If not, how will the PNC owner assure airworthiness as approved data, not acceptable data, must be used when attempting issuance of a standard airworthiness certificate? Ergo, how can that conversion back to Standard Airworthiness be accomplished without a conformity inspection to it's ATC ?
All that (and more) being said, if you, TedK and other supporters believe it's pertinent expending so much of what little political capital private aviation has, on an idea that has proven elsewhere to be of little success (1.7 % of all aircraft in Canada are in the OM category), I wish you well in your efforts.
