People often do a homebuilt to save money, but also to have something they made and often the creative side wants to customize or personalize a plane.
But CAUTION, any changes from a proven and tested design, can be dangerous.
Here are two cases.
I was minor partner in building a Starlite, the single seat predecessor of the Pulsar. It was a cool little design, single seat, low wing, glass fuselage, mostly wood wings, Rotax 2 stroke engine, bubble canopy, and sleek look, and 254 lbs and 130 mph speed.
There were fatal accidents, both caused by builder mistakes.
When the NTSB called Mark, the designer, he could scarcely believe what they found. The wing spar is a beautiful piece of spruce or fir, about 1 in by 4 in, several feet long, knot free and very strong, in one direction. It goes in the wing on edge so the main strength is to resist the bending stresses up and down, thus the full widest part is taking most of the stress. To bolt the wing onto the fuselage there is a bushing about an inch in diameter that is inserted in the spar near the inner end, and the attaching bolt goes through this bushing. Now, the hole in the spar for this bushing would weaken the spar somewhat,so the correct method is to wrap the inner end of the spar in 6 layers of fiberglass and epoxy around the spar and the result is very strong, and keepS the spar intact.
Mark could not imagine until he actually saw the wreckage, but the builder had not put ANY wrap on the spar at all. The plane flew ok for a few hours, but the bushing was working in the hole in the spar, and soon caused the spar to split and fail and of course the wing to come off.
WHAT DO YOU THINK THE DESIGNER WOULD HAVE TOLD THE BUILDER IF HE HAD ONLY ASKED? What the builder completely left out was one of the most critical steps of the job. He did not not survive so couldn't be asked what he was thinking.
Next the horizontal stabilizer sllides through a slot into the fuselage. It also has some epoxy or a wrap or some type of reinforcement, ( I can't recall for sure). The problem is that the fit is snug,and you have to get the stab all the way in in order to hook up the controls; so that each time you slide in some of the epoxy is squeegeed off when you slide the part into the fuselage slot. The builder put some epoxy on the part, but then slid it in and out several times to get it to fit so that the epoxy was mostly wiped off the part and did not do it's job, and the horizontal tail was not secure in the fuselage. This error is a little less glaring than that above and not as easily seen as the wing wrap.
The designer was actually test flying one plane for the owner, ( may have been this one) at Sun N Fun when it failed, and he was saved by his parachute.
So if you want to make any changes in a kit or plans, ASK THE DESIGNER. He may say no to cover his potential liability, or he may say yes or maybe, but you may avoid a serious mistake, and as least understand what you are getting into.
