Results 1 to 10 of 16
Thread: Tailwheel PPL near Pittsburgh?
    Hi airplanes world fellows!
    I'll be living in Pittsburgh for a year, and I would like to take advantage of that to get my PPL. Do you know guys if I can get my PPL only flying a taildragger? If that is possible, any flight school near Pittsburgh where I can go and ask? I want to get it in a tailwheel plane because I plan to continue getting training on aerobatics, (recently I bought a Rans S-10) so would be better if I practice since the beginning on this kind of plane... and well, I love the old school looking of the J3s and Champs, and want to be part of that club .
    Good flights
    Esteve.
    lnuss's Avatar
    Dec 2013
    Colorado
    Certainly you can get your Private in a tailwheel aircraft, but there are equipment items such as radios and instruments that are required for learning under the hood, controlled field, etc. However, you can certainly work through solo and even some cross country in something such as a J-3, then switch to a better equipped tri-gear (that's what I did in 1969 -- started in a Chief, finished in a Musketeer).
    All that said, though, finding a place that teaches in tailwheels (or finding tailwheels for rent) can be difficult, and finding good independent tailwheel instructors can also be awkward, though all are certainly around. But find a local EAA chapter and touch base with them, as they are likely to know about the availability of the above.
    The other consideration, in a place like Pittsburgh, is that the aircraft will likely need a radio and transponder to deal with class B or C airspace, unless you find someplace on the edge of that area with cutouts in the airspace.
    Good luck to you -- it's a great goal.
    Larry N.
    Quote Originally Posted by chacalextreme View Post
    Nothing in the regs to prevent that. However, finding someone to do it may be a challenge. And with that, no way I'd drive further or pay more just to get a PPL in a tailwheel airplane. Just find the most convenient, reasonably priced training (regardless of airplane type) and go for it. You can transition to a tailwheel airplane after you're done.
    Thank you guys for the advices! I will contact the local EAA chapter, And will continue looking for tailwheel birds! Thanks again!
    Eagle Six's Avatar
    Oct 2013
    Navajo County, Arizona, USofA
    After my private pilot, I started flying some taildraggers. I wish I could have taken my PP training in one, but the only thing at the time, within reason, were nosedraggers, so that is the route I went. Usually, but not always, my experience and observation has been, pilots become more proficient with stick and rudder when they have transitioned to taildraggers and had the training to become skilled endorsed.
    When I have a choice, I always go toward the taildragger. Recently I took my flight review after 34 years off of flying. My choice was between a Piper SE Comanche and a Cessna 120. My choice was the Cessna 120! Believe it or not, before you even climb into a small airplane, a few tap dance lessons, will improve your rudder skills. The rudder even works for nosedraggers, but with taildraggers, from the time you start the fan and roll, until engine shut-down and tie-down.....we need to work the rudder.
    Good Luck in your quest.
    Best Regards......George
    George Dean
    CP-ASMEL/I, S-6ES
    EAA, APA, & AOPA member
    KTYL/KGEU, EAA White Mountain Chapter 586 - Show Low Regional KSOW
    "If you go down, go down standing up"
    There are at least 2 skills particular to learning/flying a tailwheel plane:
    1 Limited view over the nose and out the front
    2 Need to use the rudder pedal better to keep the nose straight down the runway,
    especially on landing, since unlike a nosewheel plane the tendency to straighten out is not built into the plane and relies on the pilot to keep straight
    While you can learn in a nosewheel trainer ( C172 etc.) you will likely always have some unease about the limiited front view when you later try to switch to a tailwheel plane.
    Do yourself a favor and try to start in tailwheel first. And the best is one where the pilot sits in the rear seat, ie J3 Cub, etc. so that you get used to not being able to see straight over the nose.
    Other planes like a Citabria or Decatlon, Champ are not quite as good since you sit in the front seat and can see forward somewhat.
    When I wanted to learn to be a better pilot, I found a CFI with a Cub, (took some searching) then got some time in a Stearman ( wish I had more of this) then got enough time in a T-6 (STARTING IN THE REAR SEAT) to be sighned off and solo the T-6. Almost everyone today would tell you to start in the front of the T-6. DON"T. ONE of the SMARTEST or luckiest things I ever did was to start in the rear seat and by the time I got ready to solo and moved into the front seat I was used to the poor visablility out the front and could land the T-6 3 point from the rear seat which is very blind, ( use periphial vision).
    To this day, I may have some trouble with pitch control in the flare, sometimes I am a 7 sometimes a 9, but almost always my rudder skills in keeping the nose straight are a 9 or 10, and I am don't have to push the nose down in order to see over it when trying to land.
    I know some airline and jet pilots who fly tailwheel planes and they are always a little uncomfortable on landing and trying to lower the nose to see over it and can only make a wheel landing, very uncomfortable with a 3 point landing.
    It is something like learning to drive a car. If you learned in 1950 it would have been a stick shift and no one thought anything about it, but now you get many people in a stick shift and they make it into a difficult thing since most everyone now learns without having to use the clutch.
    The rudder pedal use can be learned by lots of practice including some when taxing, but it will be emphasized if you you start in the rear seat. If you are ever in COLO especially Boulder, get in touch with me and I can show you what I mean by rudder use in an hour or so, it doesn't take forever, but it does require good skill for when you later deal with landings in some crosswind.
    If you can't find a tailwheel plane to start in, by all means start in anything, even a 172, but if you can find a Cub, you will always have a leg up on the guy in the Cessna. It is easy to move from the Cub into a 150 or 172 when and if you need to do instrument or night flying.
    And by the way, if you go on to fly other types many of the most fun and interesting planes are tailwheel. Cessna didn't make any nosewheel P-51s or DC-3s!
    One last point, some of the modern trainers, DA-40 etc. are full of wonderous gadgets. So you can spend you time learning about gadget reading or you can spend you time learning about flying a plane.
    Go fly!
    Jul 2012
    Circle Pines MN
    I agree with everything that Bill said, except that you can fly a Champ or Citabria from the rear seat with your instructor. The front seat in my Champ has very good visibility, you don't even need to S turn while taxiing, but the rear seat is very Cub like. There's been many times I've soloed my Champ from the rear just for something different. Normally you have to solo a Cub from the rear seat but you can solo a Champ from either seat.
    lnuss's Avatar
    Dec 2013
    Colorado
    then got some time in the rear seat of a Stearman ( wish I had more of this)
    The front seat is even more blind.
    Larry N.
    Inuss where are you in Colo? What do you fly? I fly mostly in Boulder and Aspen, sometimes FNL,BJC,APA.
    lnuss's Avatar
    Dec 2013
    Colorado
    I'm in Westminster, Bill. I now have diabetes, and I've not gone through the hoops to update my medical, so I'm not flying anything currently. When I had that L-21 I flew out of Erie, but I'd been out of Jeffco for a while before that. My Stearman time was in Albuquerque in the '70s: http://home.comcast.net/~lfn3/Peg_Abq/Av_Pix.html
    Larry N.
