Results 1 to 10 of 15
Thread: Aerobatics and parachutes
    Infidel's Avatar
    Dec 2013
    Montani Semper Liberi
    I considered posting this thread in the "unusual attitudes" segment of this forum but figured it would fit here in Hangar Talk as well.
    I know of a few people that perform mild aerobatics. Some with the required parachute and some without. I was speaking with one of the guys that has a chute and I asked him if he has ever skydived as a way to acclimate himself if he should ever need to exit his plane and use his chute to save his skin. He advised he had not.
    I believe most pilots, if not all, will try to fly the plane all the way to the crash site. Even if a major component is missing and the plane is falling, versus flying. I just wonder how many people have elected to impact the ground with the plane due to fear of exiting the plane and no experience in deploying a parachute? Or the fear of free falling outweighed the crashing of the plane?
    JimRice85's Avatar
    I made 18 jumps in the Army. Unless the plane is on fire or a wing falls off/folds, I'll keep flying it so long as there are reasonably survivable landing sites.
    Jim Rice
    Wolf River Airport (54M)
    Collierville, TN
    N4WJ 1994 Van's RV-4 (Flying)
    NW FL
    It all depends on what you're flying. I was fairly well instructed in military flight school on opening the emergency exits, jumping, landing and survival. Then I got a Luscombe and guess what. No way to jettison the doors and it was a real tight fit in that little cockpit with a chute. Might as well stow the chute in the baggage compt for all the good it will do. If my Luscombe had the fuselage tank instead of wing tanks, I sure would be reluctant to try a controlled crash.
    Still, with no chute I did a fair amount of acrobatics/aerobatics with my Luscombe. Stayed away from snap maneuvers. BTW, aerobatics is a term not used by FAA. I had an acrobatic suplemant to my POH. Larson Luscombe was the first and only normal catagory plane with acrobatic approvals beyond spins and lazy eights. She was approved up through Cuban eights, rolls and snaps at the top of loops among others.
    A ballistic chute is about the best answer if you don't have jetisonable doors.
    Bob
    If the airplane is one you can get out of, and your type of flying may well have a serious loss of control or power, I think one is foolish not to wear a chute. You have to sit on something, why not sit on something that will save your life. I wouldn't do acro without a chute and I don't care if Patty Wagstaff is flying the plane. Yes, most of the time you won't need or use the chute, just like you won't need the airbags in your car of the helmet that smart people wear for motorcycle riding or ski racing.
    Chutes scare some people, it brings up the idea that something might go wrong and you'd need to use it.
    For doubters, they ought to Google the P-51/Skyraider midair at Duxford a few years back. Most or at least many warbird pilots wear chutes, but we really hope we don't have to use them. Here the Skyraider cut under the 51, and cut his control cables so he had no elevator and no pitch control. Despite not being young, the 51 pilot reacted fast and got out at about 600 feet agl. The chute opened and saved his life, not even injured.
    I know of a number of other cases.
    Using a Chute
    Being an expert in using a chute would be good, but that is not necessary. All those WWII guys did NOT have practice jumps before going into combat, just the briefing.
    If you can get out of the plane, and pull the ripcord, the chute is going to save your life almost every time.
    During the Battle of Britain, 60% of RAF pilots hit over England were saved by parachute and that is even though many were on fire or wounded. The had the advantage usually of enough altitude and of course, were not so stubborn as to negate the value of the chute.
    I have never jumped, hope I never have to, but I have done the "flying" in the vertical wind tunnel. Other pilots ought to try it.
    Eagle Six's Avatar
    Oct 2013
    Navajo County, Arizona, USofA
    No doubt there are a lot of pilots with a fear of hanging below a canopy. I haven't met any that do aerobatics, but like yourself I know of many who perform aerobatics with or without a chute, yet have never used a chute. It's no big deal skydiving, and everyone should enjoy it at least once, but doing it once at least introduces you to stepping out and the initial free fall.
    I've done (and will do) aerobatics, and have jumped out of airplanes. One of the first things I do in a new to me aircraft as part of the familiarization is the best procedure for egress. Whether on the ground or in the air, in an emergency, it may pay benefits to be able to get out quickly and cleanly. The only airplane I currently have to fly is an E-AB LSA design. It is tight getting in and out, and it also has a BRS. Personally I would feel better strapping and sitting on a chute than having a BRS, but I guess they have saved a lot of SR22 pilots/passengers!!
    Nonetheless, I agree with you. Stepping out of a jump plane isn't going to be the same as pushing off a dead bird going down, but it would give the pilot some experience in the event they have that decision to make someday.
    Best Regards.......George
    George Dean
    CP-ASMEL/I, S-6ES
    EAA, APA, & AOPA member
    KTYL/KGEU, EAA White Mountain Chapter 586 - Show Low Regional KSOW
    "If you go down, go down standing up"
    You all should watch the video of Sean Tucker's description of his last bail out here -> http://www.youtube.com/watch?v=gm4dXC7aVzs
    Very interesting and informative talk.
    Thanks for that video. I knew of the incdent but had not seen it.
    Another story is a man who takes his young son up for some mild acro in there Decthalon. The boy is only about 12 years old, but they have chutes and the Dad teachs him what to do. Something breaks in the plane and there is no control. The Dad jettisons the door and tells tells the boy to jump.The Dad says the greatest moment in his life was seeing the boy's chute open below him before the Dad also gets out.
    I wear a chute, helmet, and flight suit when doing aerobatics. It's not so much airframe structural failure I'm concerned about, but rather fire and unrecoverable spins.
    Although not strictly aerobatics related, will stress the aircraft more than unaccelerated flight and one such result may be a fire. An in-flight fire may or may not be survivable; despite having a "firewall", it's certain possible that fire still manages to enter the cabin. One such incident occurred to an RV builder/pilot who elected to bail out rather than try to land. It would have ended better if he had a parachute. http://www.ntsb.gov/aviationquery/br...99FA113&akey=1
    I do spins frequently and am not intimidated by them (my max thus far is a 9 turn flat spin with an additional 2 turns for recovery). However, it seems spinning into the ground isn't unheard of and the advice I was given prior to undertaking spin testing my RV in phase 1 was to have an escape plane i.e. a chute.
    I'll admit that neither of these situations is particularly likely - if they were, I wouldn't get into the airplane in the first place.
    Sidney, OH
    I'm not a aerobatic pilot, but I do have a lot of experience with parachutes. I spent 5 of my 6 years in the AF Reserve as a loadmaster. I've packed hundreds of parachutes and flown many air drop missions day and night dropping equipment and troops. The parachute is a fairly simple invention and very reliable. I have never jumped out of an airplane but if you wear one, even without any actual training, you will feel very secure with opening doors in flight and such. I've flown lots of "students" at the jump school in Fort Benning, GA and watched the smiles appears as they bounce back from the initial shock of the chute opening! If your wearing a parachute be sure and pay attention to the ground/water that your flying over, landing on a roof or in the middle of an Interstate could get you just as dead as flying into the ground nose first.
    Joe
