Two channel voice momentary or Trim, Flaps, or speed brake.
OTTO Industries two way momentary switch with self centering.
Center is off push forward or up channel one down or back channel two.
or flaps ,trim,spoilers up and down.
Wiring is contained in the welded throttle arm, exiting just above or below
the pivot point. Voice switch has gold contact for less static.
Pictured quadrant is a TBL2NRI-F. Available all models.
Rock and Joan
Baxter Quadrants Inc.
624 S.W. Langston Rd.
Renton, WA. 98057
(206)-303-7020
baxterquadrants@centurylink.net
http://baxterquadrants.com
