Results 1 to 4 of 4
Thread: 4-way fuel selector valve
    Feb 2014
    I assume this could be from an early aircraft but not sure so wonder if anyone recognizes it? It has four 1/4" connections with four detents for "off" and three sources. The control knob contains a feathered arrow for valve orientation and the only other marking is a diamond at the outlet. As you can see in the photo, it does wear some minor surface oxidation which gives it character just like the owner. I acquired it from a retired automotive mechanic friend who, as far I know, was not into aviation. If it is from an aircraft, I will then need to find someone who needs it for a specific restoration project because I have stored it long enough.
    Ron
    Many vintage aircraft use regular industrial fuel valves, so it's possible it came from a plane, but it's just as possible it's off a tractor or something.
    None one I recognize.
    Banned
    Not intending to be unkind - but - err steam engine?
    Feb 2014
    Quote Originally Posted by douglish View Post
    You are not unkind but very helpful, I think! Which aircraft model was powered by steam, in what year and did it burn coal or wood?
