mig welding 4130 fuse
i have decided to build a legal eagle xl but before starting I looked around for an unfinished project well I found one however I am not too sure about it. the fuse has been mig welded I have been told that the heat from mig welding cause the 4130 to lose strength. there are other concerns about this opportunity I will state them here although maybe I need to start a different thread after I figure out if the fuse is usable for me. included is a Teledyne 042 engine and prop. I am pretty sure I will go with 1/2 vw as designed by mr milHolland, the last issue is it also comes with alum. delta honcho wings I would be more comfortable with a metal wing as It would fit my skillset better than wood however I saw a post on here that stated roll control was sluggish anyone here with experience with these wings on the le xl thank you
