I have a Mini Straton D-7 and need a set of plans to check the plane over to see that it meets the design requirements. I have several questions that I need to get satisfied before the first flights. The most important is weather my Straton needs the cables that can be seen on all of the D7s seen on the internet. These run from the outer wing strut fitting to the tail.
