Good points, Wes. I'm curious now to download some other countries' databases and see if I can correlated aircraft S/Ns with the ones exported from the US.
An especially good point. The re-registration effort got started because the FAA had to go in front of Congress and admit they didn't really know how many airplanes were in the US, or where they were located. Getting rid of some of the deadwood is going to help, but there's still a bunch of things wrong that aren't being corrected by the current program. There are 20% more homebuilts in the FAA register than are officially recognized as such. I'm hoping that they'll finally recognize them as such, but there's no real incentive for them to do so.Unfortunately, there are a bunch of factors at work with the deregistrations so like many "social science" type investigations, it may be almost impossible to identify the most important cause of the change.
For example, go to http://www.faa.gov/ and enter "16JA". This is an RV-6 a friend of mine built 20 years ago. If you scroll down to Airworthiness, you'll see it says "Unknown" under Classification. This means the FAA does NOT count it as a homebuilt! If you run that number through the NTSB accident records, you'll see two accidents with this airplane (after my friend sold it). In other words, it only counts as a homebuilt when it crashes.
I've attached a list of nearly 6000 aircraft registrations that come up as "Unknown". Yes, some certified airplanes are there. Some Warbirds. Some LSAs, too. But the vast majority are recognized homebuilt types.
These all have "passed" the FAA re-registration effort. But they don't contribute to the FAA's estimate of how many hours homebuilts flew last year. The only time they're counted as homebuilts is when they crash.
Arghhhh.
