Results 11 to 18 of 18
Thread: Carbon Fiber Panels - Touching Aluminum Frame
    Quote Originally Posted by c322348 View Post
    Check out a galvanic corrosion chart where the potential voltage indicates how likely corrosion is to occur:
    http://www.thelen.us/1galv.php
    If aluminum is -1.670 and carbon is +.810, the potential is 2.48. The potential between aluminum and cadmium is about 1/2 that, at 1.268.
    Titanium pins and bolts are often used with aluminum in large aerospace structures. The potential there is 1.725, but 7000 series aluminum alloys are somewhat worse than 2000 series alloys. In most large aerospace structures fasteners are installet "wet" using sealant to keep electrolytes (moisture) out. BTW, monel "pop" rivets as used in some homebuilt aircraft have more galvanic potential with aluminum than titanium. Also, an "upgrade" for spam can owners is to install stainless steel screws to hold on fairings in aluminum aircraft. This is a "Bozo no no" in the aerospace industry because of the galvanic potential, yet it is commonly done in GA. A cadmium plated carbon steel screw, like came from the factory, would be much better.
    The bottom line here is that aluminum corrodes with aplomb in seaplanes exposed to even fresh water without being in contact with dissimilar materials. It depends upon your environment.
    The standard aerospace method is to add a fiberglass corrosion barrier ply to the carbon fiber panel and use a titanium screw. The aluminum would be coated with primer and topcoat.
    In real life, a carbon fiber panel in a dry interior space in a homebuilt isn't at much risk, in my opinion. A external carbon fiber fairing on an aluminum stabilizer used in a seaplane would be much more worrisome. Airliners and cargo aircraft that see lots of cycles in inhospitable weather are where most of these measures are most needed.
    Good post! I don't know why anyone would vary from the plans to add carbon to a aluminum aircraft as the benefits would be negligible and it would just introduce another pontenal problem down the road. I just had to retake a corrosion control class at work and aluminum and carbon are about as far apart on the chart as you can get.
    Part of the answer to your question is that there are a lot of compound curved components on aluminum airplanes that get done in composite these days. The list includes wing tips, cowlings, spinner assemblies, canopy structure, landing gear doors, wheel pants, etc. All are much easier to construct using composites vs traditional materiels. And since weight control is a primary focus of the design build process, many of these parts and others can in fact be built lighter using carbon.
    An example is the Extra series of airplanes that are designed so that the entire top of the fuselage is composite and may be removed in two pieces for inspection and maintenance of the inside of the airplane. This would really not be practical in aluminum and even if done would be heavier than the composite used. And being able lean over the side of the airplane into a large open space to inspect and lube rather than crawl into the tail cone after removing the pilot seat obviously makes service easier which means better inspection and service. So looking at what you might call a holistic view of the aircraft design, working around the potential for corrosion that comes with carbon is an overall win.
    This galvanic potential doesn't cause an immediate pitting; it does take time to develop and it depends on the moisture present to act as an electrolyte. If you separate the alum and carbon with almost any kind of electrical barrier, it stops the reaction. You just want the barrier to be as permanent as possible in the operating situation. Glass on carbon is usually preferred for longevity but a tenacious paint would do the same as long as it doesn't rub thru by fretting.
    The reason aluminum corrodes in plain moisture exposure (seaplane above) is because the heat treated aluminum alloys have microscopic precipitates of copper, zinc or magnesium which are dissimilar from the basic alum. So moisture makes a microscopic battery on the alum surface and it gradually corrodes. By applying a layer of pure aluminum on the alloy surface (cladding), the pure cladding has no dissimilar ingredients and no battery reactions.
    Sad
    I understand all of that but some builders want to use carbon for the cool factor for a straight sheet panel. I just don't uderstand why thy would want to deviate from the plans and add a future potential problem.. It is hard enough treating corrosion as it is. I worked for a major airline in the composite shop and now I treat and repair corrosion on navy aircraft and it is bad enough treating aluminum on aluminum. Once stared it is the gift that keeps on giving. There some very informed people posting on here with very good advice.
    I think that you are comparing apples and oranges. 99% of homebuilt aircraft will not see as much exposure to corrosive environments as one navy aircraft sees in one day at sea.
    Carbon fiber components offer more advantages than disadvantages. Example, I built a seat that weighs half what the original seat weighs and is stronger. The manufacturing techniques mentioned in previous posts are easy to do and reduce the occurrence of corrosion to near zero in the environment my airplane lives in. In any case, fasteners like stainless steel machine screws are consumables that it is easy to discard at annual time and replace with new. The heads get torn up and they need to be replaced regularly anyway.
    Should the material be used with some thought? Absolutely! But the advantages of the material are so great that the homebuilder community will learn how to use it. Over at the homebuiltairplanes.com forum there is a whole sub-forum for folks learning how to engineer their carbon airplanes. It is the new frontier for homebuilders who want to try working at the state of the art.
    I wonder what the gallery told Burt Rutan when he showed them his first all composite Varieze? Likely something like what Wilbur and Orville heard.
    I can just see it at creation if there was an EAA homebuilder present.
    The Lord is just finishing up Adam and Eve when the EAA guy comes up. "What ya making there? People, I call them human beings. Oh, looks interesting, what are ya using to cover them, Stits or cotton? No, it's a new thing called skin. It's pretty good, it's flexible, can hold in a lot of liquid if not punctured and can even repair itself when it suffers minor damage. And some if it is attractive, particularly the future models of Eve that I've got in mind. Well, I don't know, looks pretty simple to me, really just like an animal without the fur.
    Couldn't you come up with something more high tech?
    High tech, eh? Actually, I hear that that is something that Lucifer is working on. "
    There are many builders using carbon fiber products like Wes has elogantly described. For example.....
    This is an Aerosport Products carbon fiber overhead console. This photo is actuall my cabin cover for my RV-10. The first is the first fitting in the cabin cover and the second is after both are finished and installed in the aircraft. No aluminun touching except for the two inserts. I have no concerns about movement rubbing the paint and epoxy coatings off to cause corrosion.
    This is an Aerosport Products Carbon Fiber Symetrical panel install in Rob Hickman's (Advanced Flight Systems) RV-10.
    This is a center arm rest in Geoff Comb's (Aerosport Products) RV-10.
    Here's a RV-7 carbon fiber panel that you may have seen in AFS's booth at Airventure.
    While this may come off as an advertisement for Aerosport Products, I wanted to use some products that I was familiar with since I have all of these installed in my RV-10 as well. My intent wasn't to talk about all the great carbon fiber products that are made by Aerosport Products, but to illustrate that there are very good applications of carbon fiber in the homebuilt market. I also doubt that any of their wings are about to fall off due to corrosion any day soon.
    bob
    Bob Leffler
    RV-10 Flying
    www.mykitlog.com/rleffler
    Going back 45 yrs or more when working at Douglas, the original applications of graphite/epoxy (carbon) were direct substitutes for aluminum called "black aluminum" which resulted in much more expensive structure for no real engineering benefit. As the manufacturing technology improved, we were able to build substructure with integral stiffeners and reduce the parts count significantly and reduce/eliminate the secondary labor required to join detail parts. Plus the elimination of all the paperwork and storage for each clip and detail part. That was the real advantage over aluminum. As designs matured and metal forming constraints disappeared, the use of composites allowed tailored stiffening and shapes not possible with metals. The goal was to build commercial transports at lower manufacturing cost over aluminum and provide a weight savings in the process. The 787 was the result of all that work, although it will take time to absorb the up-front tooling costs over traditional aluminum construction.
    During these years of development, the problems of fastening, bonding, corrosion, UV exposure, fatigue, NDI, were gradually defined and solved. Now composites are being used for decorative purposes because the fiber/resin cost has been reduced and home builders can afford these parts on their planes. I guess we were finally successful.
    Bob H
