Results 1 to 10 of 19
Thread: Choosing a project
    Oct 2013
    Seattle, WA
    Choosing a project
    Hello everyone,
    I've been wanting to build a plane for quite a while and am at a point where I'd like to get a start this winter. I'm trying to make my decision and was hoping for some advice for my particular requirements and questions.
    What I am looking for in a project is:
    1. A project. I enjoy building things and this is my first requirement.
    A. Any material except wood.
    B. Needs to be kind of quiet as I am living in a duplex (no hammering rivets).
    C. Need to be able to do a lot of the work in a large 1-car garage. Major assembly will obviously have to be done somewhere else
    D. Plans or kit is fine as long as it meets other requirements (plans helps a lot with #2)
    2. Something I can afford. I'm thinking that ~35k completed is my upper limit.
    3. Something I will enjoy when it's done. It needs to do at least this.
    A. 2 seats
    B. Enclosed cockpit
    C. Capable of at least minimalist x-country (faster than 100mph TAS, 350+ lbs full fuel payload)
    D. Resale. (Would be nice to not have a total loss if I want to sell it to fund the next project)
    4. Some things I would like (these are not all required, but various attributes I would like, individually or in combination)
    A. Fast (150+mph)
    B. Aerobatic (I've never done this, but it looks fun)
    C. Off-airport landings
    D. Capable of floats later on
    E. Larger useful load
    F. Great visibility
    Now, the main designs that I'm considering:
    Sonex
    Construction (pulled rivets should be quiet enough), speed, mild aerobatic capability, grass runways ok, good fuel mileage
    Dislikes:
    Looks (though not that important), marginal 2 place, small fuel capacity, engine choices (I'm not completely comfortable with the idea of a VW, and the large Jabiru is kind of pricey)
    Zenith CH 750 Cruzer
    Construction, Visibility, good useful load, can use many engines, could add floats or heavy duty gear for off-airport, lands short enough for me
    Dislikes:
    Looks, wish it was a little faster, only the factory plane for a data point, might be boring to fly (will it feel like a C150?), bad fuel mileage
    Zenith CH 650B
    Looks like a good mix of the Sonex and CH 750 strengths, but maybe not enough faster than the 750 Cruzer to make up for losing the option of off-airport landings
    Wittman Tailwind
    Speed, x-country ability, construction with the metal wing
    Dislikes:
    Fabric means it needs to be in a hanger?, might be difficult to get much done in a small garage.
    I also like the Kitfox, Just Aircraft, and others, but they are only available as quickbuild kits which blows my budget.
    OK, any advice for how these designs fit into my requirements/desirements? Any designs that I have overlooked?
    Thanks in advance.
    CarlOrton's Avatar
    DFW Area
    Hi, Iforgot; (you really need a better first name!)
    I'm hoping you've already searched this particular forum for similar threads- there's a bunch of 'em.
    I know others will chime in, so I'll just touch briefly on things.
    I built a Sonex, so I'm partial.
    The looks of the Sonex are something you just get used to. Everyone in aviation knows it's a Sonex, but if you pull up in something else, they'll be squinting and trying to figure out *what* kind of plane it is (well, unless you go with the cruzer). Let's just say that when you pull up at your local pancake breakfast, you'll win the dead grass award.
    Regarding low fuel capacity, the Sonex will outlast your bladder. With the AeroVee engine, if you cruise at less than WOT, you'll see fuel burns in the 3-4 gals / hr range. Trust me, in ANY small plane, your LEGS and BUTT will be screaming for you to get out of the plane after about 2.5 hrs max.
    The power of the AeroVee is sufficient. It's a thrill with just the pilot, and just a tad short of C-172 performance at gross weight. Would I like a Jab? Heck yeah, but I like the (?) $14,000 money I saved by going with the VW.
    I sat in the Cruzer at Oskhosh, and I loved it. Roomy, easy to get into, lot's of panel space, etc. I don't know if they're offering a plans-only version, but I find it hard to believe that you could build it for anywhere near $35K. Not saying you can't, but just with the kit cost and avionics, you're not going to have much if any left over for the engine. Nice plane though.
    I looked at fabric planes as well before I bought the Sonex. Sorry, fabric's just not for me. I did the fabric workshop as well just to see if I'd like it. I admire the folks who can do it, but I'm not one of them! I recognize my limitations.
    Back to the cost issue, I built my Sonex for about $33K. That includes a color MGL Enigma EFIS and MicroAir comm/transponder pair. I live under the DFW Mode C veil, so a transponder was a must. I also wanted a clean-looking panel, and had the $$$ available from selling my Cessna, so I went with MicroAir. They're expensive compared to some others, but like I said, it's a clean installation, and both units talk to the Enigma, so I have frequency transfer, built-in alt encoder, etc.
    Lastly, consider the type/level of support you'll need. I'll stick my hand in the garbage disposal and assert that the Sonex community as a whole (factory & builders) are every bit as responsive as the Van's bunch. Maybe not as many of them as Van's, but just as passionate. You can call the factory or email them. I've never waited more than 18 hrs for a factory response email. I've never waited more than 1/2hr to get thru to them on the phone (and that was not waiting - they tell you if they're talking to someone else and to just call back). But if you post on the Yahoo support groups or sonexbuilders.net, you'll get an answer pronto.
    Ooops, the real lastly, again on the looks. When I was first looking for a kit, I said no way, no how on the Sonex. Ugly, small panel, etc. But when you start to look at the real data behind your questions, it's the work of a genius. The whole fuselage is a lifting body. 6+ g's? you won't find that in the lower price ranges. These birds are built tough as a tank. Find a local builder and go visit them - regardless of make/model. You can find Sonex builders on the sonexaircraft.com website under "Find a Builder."
    Good luck!
    Carl Orton
    http://mykitlog.com/corton
    Jul 2013
    Gonzales, LA
    Well, a Piper Pacer PA-22-20-150 or 160 would fit the bill in all respects.
    Find a Tri-Pacer, with a 150 or 160 Lyc in it, do a univair tail dragger conversion, and build it clean.
    Or find one that needs to be fixed up.
    It'll do 150 mph, they can be modified for floats, haul 4 people and fuel comfortably, can do off airport work.
    Only thing lacking, is aerobatic.
    Oct 2013
    Seattle, WA
    Carl, thanks for the tips. I agree that the Sonex makes a lot of sense. I think it's ugly, but that doesn't really matter. I actually like the Waiex version quite a bit, but I pretty much intend to build from plans, so that isn't an option. It is good to hear that the aerovee provides acceptable performance, but I'm not sure that I'd feel comfortable flying with it, there's not a lot of options for a forced landing around here. As for the two Zenith designs, would they be any more expensive than the Sonex when plans building and equal avionics?
    That brings up another thing I've been wondering about. What can I expect for engine cost? The Zenith can use several of the traditional aircraft engines, what could one expect to spend on a used O-200 or similar?
    As for the pacer idea,I have considered buying something like that. It would fullfill my flying needs nicely, but misses my #1 requirement - I don't get to build it.
    Thanks again!
    Jim Heffelfinger's Avatar
    Great topic. And one that needs to be opened from time to time. It allows all of us in the build process to air our individuality.
    Plans building may not be less expensive than a kit - based on time and the sadly frequent "rework" when you make a mistake and have to get another sheet of stock.
    Using matched holes and lots of factory prefab the modern metal kit is quite rapid a build. Plans building will triple (or more) the build times listed for kits and unless the builder is VERY dedicated more likely to languish in the hangar for many years.
    I ask the question - why is wood off your list? It's the easiest to work with medium.
    The Viking Engine is reaching maturity and is going through R&D for a turbo. It will not break the bank. A friend, Ken Robbers, has Sonex with a Viking and it does level flight at 180 TAS @ WOT.
    A o-200 new is over 30K, used - down to a few thousand.
    The 100-130 hp range engines are a sweet spot for many aircraft. The list of engines is actually pretty long compared to a 200hp engine.
    Perhaps more importantly - what are your family obligations? It REALLY matters. Projects are both time and money suckers. Not every relationship can cope with both being in short supply - for a toy.
    others will add their own truth.
    jim
    Something I forgot to ask... are you already a pilot and/or taking flight lessons? I ask as some of your criteria are a bit at odds with each other. Off airport and fast are usually a bit in conflict. I work in the sailing industry and find lots of dreamers wanting an off shore boat but in reality they just want to day sail once they get their feet wet during the first year.
    Oct 2013
    Seattle, WA
    Jim, thanks for the tips. I am just a few hours away from my check ride. Hopefully will have my PPL by the end of the year. Sorry that my original post was a bit long and confusing. I intended to list a few hard requirements, and then a list of "nice to haves" with the realization that some of the nice to haves were at odds with each other but not my hard requirements. I.e.: carry 350 lbs and either go fast, or land on a lake, not both.
    cluttonfred's Avatar
    World traveler
    As I am sure you know, some of your criteria are contradictory, especially the fast cross-country speed combined with off-airport operations. You might also take a look at John Monnett's earlier design, the Sonerai II. Mid- or low-wing, taildragger or trike gear, standard or stretched fuselage, all metal wings with pulled rivets and a welded steel tube fuselage and tail covered in fabric. It's a well proven design and quite fast for the power--about 140 mph cruise on a 2180cc VW. I think the original mid-wing looks the best and probably has the best performance but the low-wing, stretch model has a larger cockpit and higher gross weight and would probably suit your needs. A Sonerai with an Aerovee would be even cheaper than a Sonex and faster on the same power.
Size:  15.3 KB Name:  320px-Monnett-Sonerai-g-rily.jpg
Size:  15.5 KB Name:  IIPERS.jpg
    Matthew Long, Editor
    cluttonfred.info
    Oct 2013
    Seattle, WA
    Hey everyone,
    Some good things being mentioned here, thanks for the advice.
    As far as why not wood: I enjoy working with wood, but I don't see it as something I want to build an airplane out of. Doesn't quite have the sense of durability that metal or fiberglass has to me. Perhaps that's an unfounded prejudice on my part, and I would be willing to reconsider if there was a design with many advantages.
    Jim, you mentioned cost of a new O-200 of ~$30k, while the used cost is a few thousand. Any more definitive idea on the used cost? I am thinking for a non-new, but has enough life left. Can it get down to the cost of the Aerovee ($7k)? This is one area that I have not researched much and I don't have a feel for used engine prices. If a usable O-200 or similar can be had for aerovee prices, that is a big advantage for either of the Zeniths.
    Cluttonfred, I did list conflicting requirements, there are multiple missions that I would be satisfied with. I'm trying to decide between the sportscar and the SUV, I know they are mutually exclusive. One of the things I'm trying to figure out is if the Sonex is better at sporty than the Zenith is at utility. The Sonerai has always been a favorite, one of the planes that had me dreaming of building my own years ago. I had kind of decided that it's not as suitable for a new pilot. The small fat wing probably doesn't give much of a glide ratio, and I've read that it can have pretty quick handling. Any thoughts on that?
    Carl, you make a pretty good case for the Sonex. How many hours do you have on your aerovee? Any unexpected maintenance on it? How does it do on those hot TX days?
    Thanks again everyone!
    Oct 2013
    Seattle, WA
    Oh yeah, another design that I've always liked is the Vision: http://pro-composites.com/Vision%20Info.html
    I wish it had continued development a little more. It seems to hit a very good design point, in a lot of ways it's like a modern Tailwind. If it had a more simple wing structure, had some more examples flying, and used a more suitable core material I think it would be a very good choice. Any one know of anything else like it?
