The guy flat forgot the gear period. You have to be brain dead to not realize the gear isn't down on a CJ as it adds an incredible amount of drag. His approach speed looks way too fast also. Looks to me like he had nothing to do with stopping the engine as you can see all three tips hit the runway before the engine stops. When they picked it up the gear comes down just fine. By the way the CJ has a very good emergency gear extension system. I owned a Cj for 5 years and put around 450 hrs in it. Great airplane and I'll probably own another. Don
It's pretty hard to look cool after a landing like that. After watching the recovery video, and seeing/hearing the pneumatically-operated gear extend rather forcefully, I'd have to say it appears the landing was inadvertent, in my opinion. Doh! Figures it'd happen at a fly-in with many onlookers and cameras rolling- the guy has MY luck it appears. (No- for the time being, I'm still a member of the "those who will" club, where I hope to remain.)
I have almost had a gear up landing, was distracted by something and saved by the Cessna pilot who came on the radio as I turned base. Would I have caught the lack of drag on my own? Possibly, probably not.
I once in about 10 years of flying a T-34A came in to land and the gear did not go down. I caught it on final, no green lights, and I went around and out, and cranked the gear down by hand. The problem was found to be a short in the wiring in the rear cockpit gear switch. The would have been an embarrassing mistake had I landed that way, as the plane was already sold and I was on my way back from Sun N Fun and only had about 3 more landing to deliver it to the new owner and collect the balance of the money.
Another time I was landing at the airshow at Geneseeo and did not have a green light in the cockpit after lowering the gear, so I went around. I had mechanical indicators in the wings that showed ok, and observers on the ground that said it looked down, but you never know if it is locked. I had to fly that way for a number of hours and landings before getting it back to the shop where they found that the hydrauiic powered gear worked fine, and the fault was just the wiring to the lights.
I had an electrical failure in a Mooney and had to crank the gear down.
To try my best to avoid it, I try to fly a full pattern, not just straight in, and I use the checklist twice , especially the last thing I look at when on short final, next to airspeed.
I emphasize "gear down" on my landing checklist first, not all the other "nice to have" items that are not vital on every landing.
Most of all, I try to go slow, be calm and deliberate, and not get rattled like if the dumkoff in the tower is trying to distract you with the usual blabber.
And if something unusual happens, like yesterday when I was about the land and found a disabled plane blocking the runway, and had to divert to Longmont, I try to be very calm and methodical in lowering the gear there.
I know of a case where a pilot new to type was taking off in a Spitfire Mk XVIII , and got the nose too low on takeoff. He never even knew that he clipped a few inches off the prop tips and flew it around the pattern to a landing.
I also almost did it in my SNJ. The tower told me to go around as I turned final and I had just retracted the gear but not the flaps and then he cleared me to land. I was wondering what the hell that horn was when I pulled the throttle back. I always do a final gear check on short final and caught it there. Bill the gear on a Nanchang has a LOT of drag. Be very hard not to notice it was not down. Don
Don, that is exactly the situation where a pilot need to slow down, and be very calm and methodical. That is when something unusual happens that is out of the ordinary which you didn't expect; such as the tower telling you to go around and then changing his mind. In that case the best thing is to complete the go around and then when back on downwind do the full landing checklist over and make sure to lower the gear.
Remember the tower guy is probably not a pilot and doesn't understand what you are doing or even care if he does know. By the way, when I have to do a go around, I do it like a takeoff. I raise the gear, then the flaps and go out and reenter the pattern. Many people teach and prefer to leave the gear down on a late go around, but what you are doing then is conditioning yourself to fly that landing without lowering the gear since it was already down. Not good in my opinion.
I forgot something on a landing Sat. I switch to the fullest tank when I begin my descent from cruise altitude, I don't wait till I am near the ground and busy with other things. So I was coming over the mountains at 13,500 and going into Boulder at 5300. I was coming through 10,000 feet and made a radio position call and find out the runway is just fouled do to a disabled plane. I diverted to Longmont 10 miles north and was careful to put the gear down and recheck it, but after landing I found I was still on the least full fuel tank with perhaps 15 gal left. Another reason not to ever fly with less than an adequate fuel reserve, and how you can make a mistake when something unexpected occurs. And don't let the controller take over how you fly your plane.
I've had my share of landing gear malfunctions over the years. I carried a spare bulb in my flight bag for awhile for the landing gear indicator lights. One day, R main didn't light and I couldn't find my spare bulb. I was able to swap R main with the L main bulb and it lit. Landed with 3 green and 1 red unlock lights on and the gear held. Since then, I've always made sure that the bulbs were not frozen in the sockets and I could unscrew them to swap them around. Had to use the blow down bottle once. Seems like a simple operation, however Vlo is reduced quite a bit and you only have one shot at it. Don't screw it up by going too fast. I've noticed that there are much fewer errors with two pilots up front and they have a proffesional attitude.You cannot believe the number of excuses for gear incidents that sound so reasonable.
I hope the owner tears down that engine before further service. I'm sure he will. I used to fly with the Guard. One of my friends got off his civilian job one midnight and headed for the hangar. They had left a plane outside, fueled for him. It was the same U-1A DH Otter that another pilot had previously had a prop srike on T.O. Shucks the U-1A does every thing nose low, including climb. All 3 prop tips were bent and there were a row of nicks down the centerline. They changed the prop but not the engine. The U-!A has a P&W R-1340. About an hour or so after TO, about 0200 my friend was solo, with no moon over the White Mountains in NH when the P&W threw a rod. Less than 25 hrs since the prop strike. Al had a chute, as required by regs. He was wearing only a harness, and all the chest packs were on a rack near the aft cabin door. About 12-15 feet behind him. He mayday'ed and someone at Manchester heard him and turned all the lights on. He was suprised to find himself almost overhead and landed OK.
Bob
