Results 1 to 10 of 15
Thread: Aaaahhhhh, This Looks Vaguely Familiar
    Banned
    What is it they say about copying?: The best form of flattery. Another LSA Amphibian to add to the mix. From a new domestic company, Vickers Aircraft, it's called the Wave. Powered by a Lycoming IO-360 and with in-cockpit power wingfold. The Prototype has not flown yet, but company president says deliveries to start next summer(when will would-be aircraft developers stop saying nonsense like this...don't these guys ever learn from the mistakes and foolishness of others who preceded them).
    No weight exemption required so the process should move fast!
    Ryan Dembroski's Avatar
    Milwaukee, Wisconsin, United States
    What's a "Water Thruster"?
    Is it a jet ski type nozzle in the hull to provide propulsion in "water mode"?
    Flyfalcons's Avatar
    Feb 2012
    Bonney Lake, WA
    Most likely a lateral thruster to help water maneuverability at low speed.
    Ryan Winslow
    EAA 525529
    Banned
    Falcons has it right. It's a tiny outboard motor, should be electric, one-half horsepower. Shut down the engine, extend the thruster hidden within the fuselage and use/direct it for docking(if possible) or beaching from within the cockpit. A neat little item.
    What's the difference between a bass boat trolling motor and an aviation water thruster?
    At least a thousand dollars.
    Makes sense to me... is that sort of trolling motor/directional thruster common in seaplane operations?
    Flyfalcons's Avatar
    Feb 2012
    Bonney Lake, WA
    No it isn't. Single engine seaplanes generally rely on forward motion and water rudders to maneuver on the water. Wind, if any, can be used to help maneuver as well, but it can also be a hinderance.
    Ryan Winslow
    EAA 525529
    Aaron Novak's Avatar
    Oshkosh, Wi
    Quote Originally Posted by Flyfalcons View Post
    Hmm, looks like the GA world is following the automotive and appliance world. More gizmos and less substance.
    Flyfalcons's Avatar
    Feb 2012
    Bonney Lake, WA
    Maybe but there have been many times I would have killed for thrusters while getting in and out of tight docks and marinas. Seaplanes, even more so than taildraggers, require your full attention until you're tied down.
    Ryan Winslow
    EAA 525529
