Homebuilt WW1 Antique Aerodrome
Not sure where to put this or if there is interest, but I am trying to build a modest aerodrome, hoping to keep in a WW1 theme to match a Sopwith Camel replica. My budget is somewhat modest, so we started with 11 acres open farmland outside of Dayton, Ohio. While typical minimum RFC standards were a field 1250 x 1250, a field of 300 x 1600 was chosen with a mowed landing field of 1600 x 150 feet - enough for most all WW1 replicas to operate easily. The field was initially in corn, but was drug and Fescue 31 grass was seeded on the landing area. There is a treeline down one side, and the approaches are clear over bean fields. Clear at least when we bury a power line running down the road next month. The first call was to the township zoning inspector who gave the go ahead for the landing field. Next calls were to Ohio DOT/Av and the FAA regional airports office in Michigan to register. Amazingly, the FAA takes even the smallest registered landing areas quite seriously as far as safety is concerned. A long process, but the folks at the FAA were accommodating and tolerant of my not knowing anything. Ohio DOT/Av were great as well - very friendly and helpful. So, again keeping with the 'somewhere in 1917 France' theme, the modest airfield was registered with a very common French name: Aerodrome Les Noyers. I had researched RFC/RNAS aerodrome buildings in France, and came up with initially starting with a wooden technical shed (hangar) and a small watch office based on the Stow Maries Pilot's ready room. Stow Maries is a WW1 aerodrome in Kent, that has completely survived being isolated in the rural English countryside. There would also be a small French farm cottage to live in to keep with the ambiance of being "over there". The aerodrome will ultimately also have a replica Bessoneau tent hangar, but that is in the next couple of years. The 50 x 40 hangar and the watch office were built in cedar planking after a stone drive lined with Poplar-like trees was laid going up to the aerodrome. This tree-lined drive will hopefully be reminiscent of those many French country roads of the early 1900s. In keeping with the name 'Les Noyers', an orchard of walnut trees will be planted in front of the cottage. The watch office interior, complete with wood stove and 1915 Victrola and period maps, acts as a nice 'hang out spot' for visiting aviation enthusiasts. the hangar houses the Sopwith and has room for a future project BE2c. Feel free to check out the Facebok page under Aerodrome Les Noyers for notams and announcements. I post some more details about the mechanics of building and running a small (tiny) antique airfield if there is interest, and hope to see you all someday for a spot of tea!
