The airplane is listed with the FAA.
FAA REGISTRY
N-Number Inquiry Results
N3514P is Assigned
Data Updated each Federal Working Day at Midnight
Aircraft Description
Serial Number 22-3264 Status Expired
Manufacturer Name PIPER Certificate Issue Date 09/23/1998
Model PA-22-150 Expiration Date 09/30/2012
Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating
Pending Number Change None Dealer No
Date Change Authorized None Mode S Code (base 8 / oct) 50765566
MFR Year 1955 Mode S Code (base 16 / hex) A3EB76
Type Registration Co-Owned Fractional Owner NO
Registered Owner
Name PAYNE IRA V
Street PO BOX 1368
City WASKOM State TEXAS
County HARRISON Zip Code 75692-1368
Country UNITED STATES
Airworthiness
Engine Manufacturer LYCOMING Classification Standard
Engine Model 0-320 SERIES Category None
A/W Date 09/16/1955
The information contained in this record should be the most current Airworthiness information available in the historical aircraft record. However, this data alone does not provide the basis for a determination regarding the airworthiness of an aircraft or the current aircraft configuration. For specific information, you may request a copy of the aircraft record at
Http://aircraft.faa.gov/e.gov/ND/airrecordsND.asp
Other Owner Names
PAYNE MOVIS B
Temporary Certificates
None
Fuel Modifications
None
Like Marty said, check with the local airport FBO's and I am sure that someone knows something about the airplane.
I am at the Slaughter airport most weekends so you are more than welcome to come hang out, and if the weather is good I am always looking for company to ride along. I am currently getting the airplane ready for Blakesburg. If you are thinking of visiting send me an email and I will make sure I am at the airport.
Wacoc8@cox.net. Or, you can just wait till Marty visits in the fall and we can all go flying at the same time.
BTW, that is a really cool Pacer. I remember when Jim Younkin modified a Pacer to keep up with Bud Dakes Monocoupe 90AL. Steve Culp did the same mods to this particular Pacer. It was FAST! Pretty airplane. Hope you find it.
Dave
