I just finished reading the feature article in the August issue of AOPA Pilot on the new Diamond twin DA42-VI. This is a very 21st Century aircraft based on DA 42 NG, composite airframe, t-tail, new diesel engines from Austria, called Austro AE300 derived from a Mercedes-Benz auto engine. It comes with the Garmin G1000 panel, leather, A/C and such. Now the Pros for this aircraft are it's simplicity of operation. The engines are FEDAC, you select your flight configuration either fuel efficiency, or speed and then start the engines just like your car. Type in your flight plan and cruising altitude, set-up the auto-pilot and get your clearances. The main job of the pilot after take-off is to monitor your progress and communicate with ATC. While this is a very efficient way to fly, more precise and probably safer it seems kinda boring to me. Since it's diesel powered it will run on Jet-A so no future 100LL type issue. Another plus in the fuel area is it's low fuel consumption, less then 10 gal/hr total (both engines) at 55% economy cruise, 144Kts. The engines are automated to the point that prop pitch is set for optimum performance without any pilot input other then the selection of performance efficiency desired.
OK, here's some down sides, the base price is $731K and the one you want is $938K! This is for a 4 place light twin with 168 hp engines, 1200ft/min climb rate at sea level, GTW 4189 lbs and 52 gals of fuel.
Since I fly a '58 TriPacer I'm not in the market for this kinda aircraft, but it really does have some kool pluses. Those of you building RV's and such ever look at FEDAC engines or these high tech diesels?
I thought this might make for an interesting topic, but keep in mind i'm not looking for a rant about Sport Aviation, this was in AOPA Pilot.
Joe
