Results 11 to 20 of 20
Thread: What airplane to build?
    CarlOrton's Avatar
    DFW Area
    Take a look at the Onex; http://www.sonexaircraft.com
    Carl Orton
    http://mykitlog.com/corton
    NW FL
    Mike, the T-18 was designed from the begining with a quick detachable wing. 1. Detach the stabilator push pull tube from the sticks. 2. Detach the wing from the fuselage (4 bolts) 3. Lower the wing to the ground (sticks still mounted to the wing center section, ailerons still connected. 4. Walk off with the 23 foot wing. Forgot to mention disconect nav lights. No fuel in the wings, its all in the fuselage.
    Bob
    From what I have read, the S-18 has a true folding wing. Personally, after reading about both I don't see that one really has an advantage over the other. Both probably require 2 people to do it easily.
    Wilmington, North Carolina, United States
    Carl, I've got that on my list. What do you think as a builder? I don't have any sheet metal experience and have never built a plane. Could a 'beginner' take on a project like that? Thanks!
    I've saved the book mark for your log, ships coming together!
    I flew into Addison once, but fuel was much cheaper at HQZ!
    Quote Originally Posted by Neil View Post
    This came up in another thread here. My first build was a Sonerai II. I really liked the airplane and it had folding wings as well.
    Thanks Neil, I've put it on my list to research, sharp looking plane too.
    Quote Originally Posted by David Darnell View Post
    A Lot depends on the "mission" requirements. Another thought- the Kitfox?
    David, I just took a look at the KitFox site, neat looking plane. It's definitely on my list to research now. Thanks!
    As near as I can tell, if you want folding wings on a Thorp, unless you come up with a set of plans you have to go with the S-18, and they only sell the plans with the kit.
    Thanks Mike, I'll look into it, but I know I'm not ready for 'built from plans'. Gotta get some experience with some sort of kit.
    Quote Originally Posted by Don White View Post
    Check out this page http://thorp18.com/
    and this is the company selling the S-18 kits http://www.classicsportaircraft.com/
    a kit may be a good thing for that plane, there have been cases of the wings not being built the same which makes one drop bad in a stall
    I was interested in them until I found out I was a bit large to fit...
    Eric Witherspoon's Avatar
    Tucson, AZ
    Check my website. The Sonex was my first (and second) homebuilding projects. They are designed to be relatively easy to build. I'm trying to remember something I needed help with (other than asking questions on their Yahoo group or emailing the factory directly). Yes, drilling the wings to the fuselage and putting the wings on at the airport. That's about it.
    What did I have for experience? The Sportair weekend workshop for sheet metal. Sonex also offers a weekend workshop at the factory (and I've done that too), but I would recommend the Sportair one as it's 16 hours of hands-on metal working. The one at the factory has a little metal project, but also spends a good bit of time on marketing, history, their other products, their engines, etc. (it's at the factory, so of course they're going to do some marketing to the audience). Other positives of the factory workshop is you get to see the whole operation - where exactly your kit is coming from and meet the people who support it. But I'm just saying their demo metal project probably isn't quite enough to give good confidence to start digging into a $13k kit of parts...
    Other things I would recommend as a first-time metal airplane builder: visit other metal airplane projects in your area (join the local EAA chapter and ask them) to see what quality level you should be looking for in your own work, and have someone who has built and flown a metal airplane stop by your shop after you've made some parts but BEFORE you have attached any two parts together. That way, if you aren't getting the edges smooth enough or whatever, it's easy to fix. If you can get to Oshkosh or another regional fly-in with some homebuilts, you'll find yourself looking VERY closely at the metal airplanes, for any/all exposed metal parts you can see.
    Onex already has a HUGE support system - over 1500 Sonex builders/flyers + the gathering numbers that have already signed up and started building Onex. Lots of websites, very active groups on Yahoo, regional Sonex-specific fly-ins, people with flying Sonex aircraft to look at (and maybe get a ride in) in many locations. Since Onex kits/parts just started shipping to customers a few months ago, I'd say that by the end of 2012 there will be more than one website that has photos of EVERY SINGLE part in the airplane, every assembly, and most of the major steps documented in photos and text. That said, their plans are excellent, and contain all the information necessary to build it, but all the photos and blogs that builders will produce just adds to what you can use to get it figured out.
    http://www.spoonworld.com
    CarlOrton's Avatar
    DFW Area
    Hi, Don; sorry, took me awhile to get back in.
    Yeah, what Eric W said above! About sums it up!
    Carl Orton
