Has anyone seen this at other airports? New airport manager at Sedona KSEZ has published a draft airport operations manual, which among other things, has increased rules and regulations about what can and cannot be done in hangars. FYI - hangars are privately owned, owner pays land lease to County for the pad.
SOCAA = Sedona Oak Creek Airport Authority
"If the aircraft in the hangar is an experimental aircraft under construction, it must show continual signs of progress in the construction, through hangar and logbook inspections conducted by SOCAA. SOCAA may also ask that a "Progress Plan" be provided which outlines the anticipated time frame for completing the construction of the aircraft."
Dave
