Scott, When do you arrive? I'll give you a ride if we are there the same day as your arrival, we did that trip once.
Scott:
Call me when you arrive. I'll meet you by the fence of the N 40 in my pickup, get your gear & take it and you to Sleepy Hollow. We'll be in Sleepy Hollow by noon Friday the 26th with our 5th wheel.
(405) 417-6077(c)
malexander, thank you for the generous offer and we will definitely call you, if it's not asking too much. Our current plan is to depart Valparaiso IN at 8:00am ET, which should put us on the ground at OSH around 8:30am CT, assuming the weather forecast holds. By the time we secure the aircraft and get our gear to the fence, it will likely be 9:00am to 9:30am CT. Thanks again for the offer ... see you in a couple of days!
