Originally Posted by
Bill Greenwood
One thing about flying with Hal, does your niece really look good in brown and gold?
I don't have a biplane or open cockpit plane, but I am planning on coming in my Bonanza and will be glad to take you up if you'd like. I will base it at Fon Du Lac most likely so no problem getting in an out of Osh, and there's no need to pay anything.
My preferred time is the early evening after the show, but can do most any morning also if that is needed. I am comfortable with formation flying as long as we brief it, and used to do quite a bit of it for photos. I used to be a photographer myself, back when cameras had film as God and Kodak intended. Only time I am not available is Wed. afternoon when I am doing a forum or Thur am when I am attending one.
Good luck to your niece.
And by the way, if by any chance she is going to basic training at Lackland, see if she can go in spring or fall, Not in the summer when San Antonio gets HOT. I went in spring and if you don't mind fools screaming at you and little or no sleep it is servivable. You can do most anything for a month or so.
And if I can't help you I can introduce you to some pilots who probably can. And I would also suggest getting a number of shots on the ground in case the airborne ones don't work out. I can help you with that again, but really you can walk up to most any owner of a nice plane and ask politely if you might get a photo of her sitting in the cockpit. Most will say yes. Just ask when they are not so busy, don't wait till they are getting fuel or on their way to a pilot briefing.
And I wouldn't leave my niece alone with any pilots, but the old guys at the north end are mostly harmless.
